1982 Austin Mini - Project Who?
852 replies to this topic
#256 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 16 May 2015 - 08:42 PM
Had a long hard day in the garage, slow progress again but progress none the less.
I needed to make and weld in a repair piece for the bottom front corner of the RH door surround, the LH one will also need doing.
I knocked up a template using a Thatchers Cider Box that we had recently emptied :-) and cut out and marked a piece of sheet steel.
The first bend was easy and luckily I was able to make the next tight bend using the edge of my home made bending vice:
The next bend was made by turning it upside down and using the bender:
Started bending it the wrong way at first, but then corrected myself :-)
On test fitting (after a little correction, it was a pretty good fit:
At this  point I was still contemplating how to proceed as initially I was just going to plug weld the holes you can see in the inner edge:
First I cut them out with a 1mm cutting disc but then after spotting some pitted rust on the underside I decided to cut the whole lot out!!
Due to the complexity of this piece (it has a few reverse folds and curves) I decided to make it in two pieces. I trimmed up the outer edge piece and formed the curved edge.
To help with making the inner piece I welded the first piece in place. I had the welder set higher than I anticipated but it worked well so I left it.
I made the inner piece and made several cuts along the flange to make life easier, I then welded these up. Before welding them up I first made sure that the piece fitted exactly and only put a spot of weld on each cut before test fitting it again. This was to ensure that whilst welding the piece would still fit. Once I was happy I welded up the cuts in the flange.
Here it is held in place and fitting snug:
I also drilled three plug weld holes.
And here it is finished, took forever but very please with the result. I need to adjust the front profile a little as the Door Check was a little tight.
No time to Epoxy today so I flashed a bit of Etch Prime over it to preserve it for now.
I could clean up and repair the front wing but I really need to get the back wheels on so I am contemplating fitting both Sills, Rear Valance Closer and Rear Valance so the I can paint the rear underside and fit the Subframe?
Or I crack on with the Inner and Outer Wing and Flitch on the Left and then move to the right hand side?
Mmmm decisions, decisions :-)
#257 ryan22_lgm
ryan22_lgm
  • 1,478 posts
Posted 16 May 2015 - 09:49 PM
Proper job mate! I just don't have the patience to make my own panels just end up wasting all my money on them :( Looking foreword to the next update!
#258 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 16 May 2015 - 10:48 PM
Thanks - I know what you mean, the problem is you cannot buy just a door step corner, I think the smallest panel I have found is the complete lower section which includes the panel that covers the Subframe Mounts.
If I could claw back the time spent fabricating and spent more (that I don't have) on panels I would have finished this years ago :-)
#259 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2015 - 06:44 AM
Lovely repair there. Very neat.
Ben
#260 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 18 May 2015 - 06:46 PM
Ben
Thanks Ben, 1000% better than it was too :-)
#261 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 19 May 2015 - 07:36 PM
Found this little badge when I took the top dash apart, it's now on my Mini Cash Fund Pot :-)
#262 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 19 May 2015 - 07:51 PM
That's a great little find, good use for it too. All I found was a penny. Too rusty to spend.
#263 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 28 May 2015 - 07:53 PM
I created a list of jobs left to do on the Mini to get it rolling (let along looking smart) it equated to about 12 days work (that's full days) which normally means double :-(
Anyway here are some photos showing a few jobs completed using the odd spare half day here and there.
First of all I wanted to finish repairing the Rear Valance, its got a lot of holes in it from Spot Welding etc and when I refit it I want to weld from the top through the boot floor lid.
So using some flattened copper pipe I set about plug welding up the holes:
Here's the finished article, not dressed the welds down yet as I want to wait until I have a few other items to Epoxy.
Next I carefully trimmed the tin worm from the lower front wing:
Then using some cardboard I made up a template and marked up some steel:
A little fettling and folding:
Thought I took a pic of the welds but here it is dressed down:
As you can see I cut the repair piece to make it fit in two parts:
A little blow through on the second as the copper backing slipped:
And a third section:
Carefully welded in:
And dressed:
There were a few other holes that needed to be filled, some of these were Self Tapping holes for the Grill, they have become too large and the grill was not a good fit so I'll re drill them:
The upper wing was in better condition:
And easier to patch:
Then some Zinc Etch to stop the rust:
Didn't take a photo of the two together but they are a good fit :-)
#264 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 28 May 2015 - 08:09 PM
Much more satisfying than just sticking a new panel in, great work.
#265 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 May 2015 - 07:57 PM
Thanks Hendred
#266 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 29 May 2015 - 08:19 PM
Set about fixing the LH front Door Step today so I could maybe get the Sills on to fit the Subby and get this thing rolling again?
Anyway while I was over the LH side I had another look up inside the Arch to remind myself how bad it was and assess whether or not it would need as much work as the RH side?
Pulled back the insulation around the LH vent and saw this..............
Absolutely shocking, scary to think this got through its last MOT, I understand that they don't pull out carpets and the like but its horrible to think how much rust was lurking hidden away.
The A Post Closing Panel is rotted in exactly the same place as the RH one but the upper Flitch seems worse?
You can see in the pic how someone has just welded a plate straight on top of the rust!!!
Another big repair job coming up :-(
I started to cut out the area of the Door Step but realised that to do it properly I needed to remove the Door Check so out with the Spot Weld Drill Bit and with a bit of effort, voila (Removed the A Panel first).
Here's the area of rot on the door step before taking out the A Post and Door Check:
 First cut along the bottom and wire brush to check for rot:
And with a little more cutting, I then used the template I made for the RH side and modified it, cut out some 1mm steel and did some folding and fettling and here it is ready to weld in place:
That was about 3 1/2 hours work then in for Tea and Medals and Series 5 of Game of Thrones :-)
Plan for tomorrow is:
Weld in the Doors Step Repair.
Clean up inside A Post.
Locate and fit bolts in floor for Pipe Work.
Clean and Epoxy Paint next lot of panels (Door Check, Flitches, Jacking Points, Rear Valance Closers, Rear Valance, Scuttle Closers, Scuttles, Sills).
Clean Underside Rear and Under Door Steps and A Posts as Required and Epoxy.
If time (I doubt it) clean up RH Inner Wing and Epoxy?
Big task but if I get the painting done then I am ready to start.
#267 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 30 May 2015 - 02:13 AM
You are doing really well with those repairs.
well done
Ben
#268 Hendred
Hendred
  • 484 posts
Posted 30 May 2015 - 07:12 AM
Superb again
John
#269 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 30 May 2015 - 09:53 AM
Good progress.
I am sitting with a very similar rusty lip I need to replace. How did you manage to fold the lip? And so neatly?
#270 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 30 May 2015 - 11:21 AM
well done
Ben
Superb again
John
Thanks fellas :-) Just welded in the LH Door Step Patch - sweet
