Weld Grinding With A Dremel!
35 replies to this topic
#31 Richard1
Richard1
  • 56 posts
Posted 01 April 2011 - 07:22 PM
With a little patience I had good results. here you can see a spare tire holder I made for my Corvair. The basic grinding was on a bench grinder, and I probably should have taken it down a bit more before starting with the mini-grinder. I went through a couple of the stones, plus did a little with a diamond and some final with the sanding discs.
Final sanding by hand
Then chromed
Now it holds the tire in place
I have used this mini-grinder for a lot of the restoration of the Corvair, the trim (mentioned in the other thread on polishing). Very handy.
#32 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 01 April 2011 - 09:18 PM
Nice work, i did something similar with a replica roman soldier helmet i got from our up helly aa squad one year ( google up helly aa, it'll take too long to explain!!) It was made in India from mild steel prob hand made, was quite good but a little rough around the edges. Spent a couple of nights with sandpaper from 40 grit to 1200 and a polishing mop on the bench grinder, came up a bute!! The little dremel things certainly have they're job but also limits. Sold my draper equivalent and bought a die grinder, wonder if they have polishing mops for them or do they spin too fast?
#33 Richard1
Richard1
  • 56 posts
Posted 01 April 2011 - 09:21 PM
I should have mentioned that this piece started life as two bolts, one nut, and one motorcycle shock absorber shaft.
#34 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 01 April 2011 - 09:24 PM
Ralph Nader would have a fit!!!
#35 Richard1
Richard1
  • 56 posts
Posted 01 April 2011 - 09:26 PM
Without the Corvair he would have been just another ambulance chaser. The Corvair made him a somebody.
#36 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 01 April 2011 - 09:27 PM
And he ruined MG's with the silly rubber bumpers as well!!
