They do need some pressure on them to work well so really the Dremmel would not be man enough. Then you go on to the next level of expense. YOU WILL need a decent compressor providing a high enough CFM rating for these to work well as die grinders are air hungry beasties.
I have a 3hp twin cylinder 100 litre compressor which although works reasonably well is only just sufficient to work my die grinder work well. It just takes that little bit longer to grind the welds down unlike at work where i get full constant air pressure due to the heavy duty industrial compressors we use.
I have used them with my old 2hp 50 litre compressor but it was painfully slow.
PLEASE DO USE GOOD QUALITY EYE PROTECTION as the swarf/dust that comes off these burrs is small but very sharp and if you get a bit in your eye you will know about it. Where gloves as well as the splinters when they get in your hands/fingers (and they will) is a ******* to see and remove.
Edited by sonikk4, 26 March 2011 - 12:03 PM.
