Grinding Dust
Posted 25 March 2011 - 09:30 AM
Posted 25 March 2011 - 11:57 AM
Iain
Posted 25 March 2011 - 03:27 PM
its red hot for millisecond as the particles are so small and are flying through the air which means they have probably long cooled before hitting the bodywork but thats only my experience
Posted 25 March 2011 - 07:15 PM
You'll probably find they are quite deeply embedded in the paint anyway as the stuff is usually red-hot as it comes off so is easily hot enough to burn/melt it's way into the paint when it lands. Budget for respraying any affected panels and move/cover your car next time.
Iain
I have to agree with Iain here the grinding dust is a sod to get rid off once its embedded in the paint. My Passat is covered in it and its in the Lacquer which is a right downer also the dust had got on our double glazing uvpc surrounds and has rusted into the plastic.
If you remove it straight away then you may well get away with it but once it starts to rust it seems to cling to the surface.
I have T cutted numerous times to no avail and i have had to use Acetone on the plastic sparingly to remove the rusty deposits so a lot of work even though the car was out of the way. The wind has spread the dust everywhere which had caused the other problems.
You maybe able to flat back and mop but if not then re painting maybe your only option.
Posted 25 March 2011 - 10:07 PM
i think there is a newsh product called iron x of something, might be worth a look.
also bilt hamber is supposedly good.
Posted 25 March 2011 - 10:14 PM
So I would expect it to have gone quite deep into the paintwork
Posted 25 March 2011 - 10:16 PM
try using a detailing clay, i use sonus clay quite alot as i get a bit of rust deposit on my focus st from both grinding near the car at home and from the works car park (i am a metalworker) . they do different strengths of clay dependant on how much contamination there is in the paint.
We have tried the clay approach but to no avail which is a bit of a bummer. It will take out a lot of impurities but once the paint is damaged its game over.
Posted 26 March 2011 - 10:52 PM
Bryan
