Mini "mk3" Project Gien
#106
Posted 05 November 2012 - 08:25 PM
#107
Posted 06 November 2012 - 06:48 AM
Its great to be back , the shell is in a state of contiuing change , as I am struggling on deciding to do a flip front or not.
Thanks for the kind words Jared , its great to have a brother in arms on the MK3 front.
Cheers.
#108
Posted 06 November 2012 - 07:45 AM
Again, great project.
#109
Posted 06 November 2012 - 02:12 PM
... no chrome but I do have the MK3 Badge on the boot.
Cheers.
#110
Posted 06 November 2012 - 05:28 PM
Edited by The Principal, 06 November 2012 - 05:31 PM.
#111
Posted 07 November 2012 - 07:31 AM
Looking at your pic's showing the vented Disc's mounted on the subframe it looks like you may have the discs on the wrong sides. You need to spin the brake dust away from the hub via the disc grooves as they drive forwards if that makes sense.
That is not entirly correct. The grooves in the disc has nothing to do with brake dust. Grooves are there to reduce pad glazing. What you said hold true for a vented disc that has a backwartd shaped vane in the center, but then that is for cooling. On these discs the vanes for cooling are prependicular to the center of the disc so these discs can be run in either direction. As the are now they will just "clean" the pad more aggresively than when they are the other way around.
I know Lourens probably just did this without even thinking about it or knowing the differance but I have done extensive research about it for my previous car and that is the short answer.
by the way Lourens your car is going to slow. I will probably be done with my supercharger kit before you even o to paint.
Otherwise it looks good, maybe a little gay.
#112
Posted 07 November 2012 - 09:05 AM
Thanks for that. Do the doors then have the inner "latch" like the later Mini's to lock and unlock the door?
#113
Posted 07 November 2012 - 10:11 AM
Cheers.
#114
Posted 08 November 2012 - 09:18 AM
He doesn't have pockets or any other funny bits which is funny cause when he bought the car everything was original bar one door handle that looked like it came out of a mustang.
Do you want normal doors?
#115
Posted 08 November 2012 - 12:55 PM
Jared, the doors Lourens has is like the 1275E orr more modern doors.
I'm just attempting to try and find a pattern with the doors. I have noticed that on the '69 and some '70 models, the doors are like mine. But at some stage the doors changed because of rattles etc. that were experienced. So I'm just trying see when the change over was. And no, I very much like and value the doors I have, they aren't so easy to find.
#116
Posted 12 November 2012 - 06:58 AM
Been busy over the weekend with the rear subby...
Did some assembly on it, but it looks like I will be taking everything apart again tonight.
Here are some pics...
I will update tomorrow on tonight's progress.
Cheers.
#117
Posted 12 November 2012 - 03:44 PM
Just out of interest, what made you go with the coil springs?
#118
Posted 13 November 2012 - 07:26 AM
I don't really know why, I just love the way thy look. I think its something a bit more modern to do... Jury is still out on how well they will ride tho.
Cheers.
#119
Posted 13 November 2012 - 01:20 PM
I'd be interested in knowing the results of the handling and ride though.
#120
Posted 20 November 2012 - 08:26 PM
