Rolling Roads - Is It Worth It
38 replies to this topic
#31 Pauly
Pauly
  • 4,213 posts
Posted 22 March 2011 - 05:33 PM
To repeat what others say. A RR session is very wise move when doing performance mods to your engine, setting a car up on idle is just that, you aren't really altering the fueling through the rev range and under load conditions which involves re-profiling the needle. But a car can be tuned without. If your running megajolt or any other form of mappable ECU with data logging functions and have a decent wideband lambda sensor and AFR gauge, if you have the time and patience you can set your car up yourself on the road.
After my rolling road session my engine made 110bhp and 97lb/ft of torque (@ flywheel) before it was in the region of 80 odd bhp, so it is worth the money IMO.
#32 finch661
finch661
  • 2,339 posts
Posted 22 March 2011 - 06:44 PM
wow thats some difference! i feel more could be squeezed out my car, plus solve the fueling issue
#33 finch661
finch661
  • 2,339 posts
Posted 25 March 2011 - 04:04 PM
just phoned minimaster, they're moving at the mo, and wont be able to tune my car till the end of May. Are there any other mini garages with a RR near that area/part of england
cheers
#34 msl275
msl275
  • 24 posts
Posted 25 March 2011 - 04:46 PM
just had mine rr yesterday 998 stage 1 fitted aau needle at minisport padiam 55bhp it developed a electrical fault half way through 1st run so rob (tuner) sorted it out and everything was brill cant fault the guy 2hrs in all £60 not everybody would agree but i personally cant knock em :alien:
#35 finch661
finch661
  • 2,339 posts
Posted 29 August 2011 - 07:48 PM
sorry to dredge up this old thread, but does anyone know if minimaster are back? they said they would be up and running by may/june?
#36 Ethel
  • 25,919 posts
Posted 29 August 2011 - 08:09 PM
It wouldn't take much driving to recoup the cost in better mpg these days. Also, any standard Mini built to run on leaded fuel now has compromised engine tuning.
Even so it can be very expensive, or a wasted trip, if they aren't able to fully set up your car because it has worn or faulty components, and adjusting mechanical ignition will be fairly crude without a lot of work. If the car runs anything like, a decent operator should be able to profile the existing needle. Get them to plot the correct advance curve & you can work on that after the session with just a timing strobe & rev counter.
I thought of Minimaster, not realising it's an old thread, looks like their site is still shut but there is a contact email addy you could try.
#37 valve bounce
valve bounce
  • 694 posts
Posted 29 August 2011 - 08:31 PM
no mini master are not back yet witch is a shame as its was handy for me with them 2 minutes round the corner from were i work.
word is in the area they went bust but this is just the roomer i heard going around.
#38 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 29 August 2011 - 08:48 PM
There is a guy near me who has a mobile Rolling Road in a truck, he knows nowt about engines though, he just gives you your BHP.
I must get him to set it up at shows and stuff because he doesn't use it very often.
#39 jaydee
jaydee
  • 8,565 posts
Posted 30 August 2011 - 09:14 AM
Even tough RR session is a must for a Mini, it is worth only if the operator really knows how to set up A series engines.
Many of them just try to achieve the higher BHP figure at top end, letting the engine run very rich.
At this point it could better to do a long journey to go at a reputable mini-minded RR than having a session at a local one if they dont know what they're doing.
