Project Paddy A Long And Slow Rebuild.
1096 replies to this topic
#91 minifcd
minifcd
  • 246 posts
Posted 11 July 2012 - 09:28 PM
Sounds like thats gonna keep you busy then! You'd best get a bed set up in that garage then, as you'll be spending more time there than at home!
#92 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 11 July 2012 - 09:30 PM
It looks that way Scott. That,s where Paddy will be having his panels done next year.
#93 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 21 July 2012 - 08:08 PM
Paddy decided to throw up a surprise for me this week and not a pleasant one either. When we were running him up to temperature last week we both noticed some steam coming from the rocker box. Further investigation showed up a load of mayo in the rocker so it was time for a clean up and another oil change.
So the rocker box came off and i was met by a sea of rust over all of the rocker gear and spring caps. GUTTED!! then there was the 1/4" of mayo in the rocker box. Bugger. So with some judicious scraping and wire brushing the majority of the rust was removed and the mayo cleaned out. A large magnet then removed all of the loose scrapings and wire strands followed by a thorough flush with white spirit.
So with everything cleaner it was time for a new filter. The old one replaced by me last year was a pig to get off but off it came. Went to put the new one on and no go. It turned out the thread had been damaged on the filter housing previously either by me (possibly) or by the previous owner. Fortunately my friend Paul has a lot of engines floating around the workshop so rescued one of those and happy days, Paddy is now clean internally.
So attention was turned back to Pauls Cooper.
I fitted a nice new shiny Scuttle
while Paul removed the shock absorber mounts to find this
and ended up doing this
We had spent a day at the beginning of the week lining up all of the front panels with the left side coming up nicely but the right just would not go. However its nearly there so hopefully when his wings are back from being media blasted we shall get the right side sorted.
Also there had been so iffy repairs to the floors so the right side i cut out and fabricated a new repair panel for the flitch and am in the process of making one for the floor
The l/h side has to be sorted yet
#94 grahama
grahama
  • 2,442 posts
Posted 21 July 2012 - 09:07 PM
Long time no hear!! Nice thorough work as ever Neil.
#95 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 21 July 2012 - 09:11 PM
Agree Graham - he's one of the welding and fabrication elite!! But he's crazy. Its bad enough putting time in on your own car!! Good to see you back Neil.
Hugh
#96 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2012 - 04:52 PM
Cheers Hugh and Graham its nice to get welding again.
While i'm waiting for a floor panel so i can chop it up a bit it was time to reskin the doors on the Cooper.
Now externally it looked good but when you looked inside it was a different story. Also Paul never mentioned any issues with the door hinges but the door structure is severely cracked.
So after stripping the door the skin was whipped off
and the extent of the damage became clearer
So the door frame needs new flanges all round as well as repairing all of the cracks.
Also to highlight what is talked about a lot on rust threads is the hidden rust forming under flanges. Externally the skin looked good but you can see from these pictures the rust forming under the flanges which would have eventually eaten its way out through the skin
And although i have not started on the other door i have got this to look forward to
So tomorrow will be a day of flange and crack repairs then on with the skin.
#97 Minidarren83
Minidarren83
  • 1,207 posts
Posted 10 September 2012 - 05:25 PM
oh my favourite working on flange and crack (sorry couldnt resist) nice to see you back on the horse as it were look forward to your usual expert repairs
#98 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2012 - 06:06 PM
Cheers i was going to do a witty ditty about flanges and cracks but had to hold my tongue so to speak ;D being a moderator and all that good stuff.
#99 minifcd
minifcd
  • 246 posts
Posted 10 September 2012 - 08:53 PM
Oh dear Neil! And I thought my doors were bad! They're looking pretty badly cracked and rusty. Take a look at my project If you get a chance. I've just done some door repairs, so it might help you a little to see how I bodged mine together.
#100 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 10 September 2012 - 08:56 PM
Cheers Scott will do. :highfive:
#101 paul1275s
paul1275s
  • 55 posts
  • Local Club: EDMC
Posted 11 September 2012 - 11:06 AM
to be honest Neil I had never really looked at them that close, I just used them to get in and out of the the car! They are a bit badgered though aren't they!! Floorpan repair section arrived this morning, less than 24hrs after buying from fleabay.
#102 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 11 September 2012 - 06:49 PM
Just goes to show Paul how things go but no problem its going to be sorted.
The bottom lip was removed
and then the new lip pulse welded in place
and then cleaned up
so on to the hinge end of the door frame
the old lip was cut off and then onto the cracked end
damage all cut out ready for cleanup and treatment of the inner support
new section welded in place and new lip added
that will get cleaned up tomorrow and then the other damage sorted
#103 minifcd
minifcd
  • 246 posts
Posted 11 September 2012 - 06:58 PM
That is some of the neatest welding I have ever seen Neil. Would almost be a shame to put the grinder to it!
#104 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 11 September 2012 - 07:06 PM
WOW, do not grind them flat
#105 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
That's the problem Scott but its got to go but at least i know that penetration is not going to be an issue.
    Bing (3)
