Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#826 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 02 September 2017 - 08:46 PM
Right i have now completed 100% of all of the sealing ( i know i have said this before but now its the truth.)
So lots of taping
And all sealed.
#827 blueovalcraig
blueovalcraig
  • 193 posts
Posted 02 September 2017 - 09:42 PM
Looks awesome
#828 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 02 September 2017 - 10:07 PM
bravo  :highfive:
#829 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 02 September 2017 - 10:55 PM
Another milestone passed in this epic adventure.
#830 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 03 September 2017 - 06:55 AM
Some very tidy work there, it will all be worth it once that paint goes on :)
#831 gadget555
gadget555
  • 152 posts
Posted 04 September 2017 - 09:20 PM
Lovely sealing lines
#832 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 05 September 2017 - 07:17 PM
Primer time then!  :gimme:
#833 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 05 September 2017 - 07:31 PM
Got to remove the multiple layers of paint around the upper part of the rear screen, C pillars, side window frames, upper door cutout and the windscreen frame. Then its primer time.
Too many layers of paint for my liking so it all needs to go. Gone too far for old paint to react with the new stuff.
#834 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 08 September 2017 - 07:53 PM
No work on Paddy today but extra lights fitted in the workshop
and preparing the filtration system for my breathing air. Two airline adapters fabricated.
#835 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 16 September 2017 - 06:46 PM
Not a huge amount of work done, busy collecting final things needed like new heaters, 16amp extension lead etc.
However the seam strips needed sorting along with the door hinges so these all got paint stripped, rust treated then epoxy primed.
And while i was at it i applied a smear of sealant on all the remaining flanges on the window apertures. No more water getting in.
#836 pete l
pete l
  • 1,368 posts
Posted 18 September 2017 - 07:20 AM
Hi Neil,
I would like your advice on some epoxy primer that I bought.
I am removing the boot floor which I had already painted in epoxy and the paint is cracking and peeling off as I bend the metal while removing the floor.
I don't know if this is normal, what do you reckon ?
Pete.
#837 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 September 2017 - 04:34 PM
Hi Neil,
Pete.
Hi Pete,
it should not crack and lift so it sounds like it was not sprayed on clean bare metal. Defo not normal.
#838 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 September 2017 - 08:18 PM
Onwards with paint prep and its off with all of the Heritage Ecoat. Too many spider tracks of rust lurking so it all has to go.
And two areas that need some minor filling
The bottom area that is dark is a low spot
And the black spots on the wing are some dimples.
That will all get sorted tomorrow along with some minor filling on the bulkhead and a few other areas i found today.
#839 Daz1968
Daz1968
  • 2,058 posts
Posted 18 September 2017 - 08:41 PM
Looking good, it always feels a mammoth task on final filling and then high build priming and flatting to get to a stage you are happy with, but once it's done it's a good feeling, shouldn't be far off though now
#840 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 20 September 2017 - 07:24 PM
So on with the filling, lots of small stuff
And its come up well but still adding bits here and there
Then while the filler was hardening it was onto some minor metalwork missed earlier in the build
And i clean forgot about the bloody door mirror holes. Bugger!!
And a bit of copper pipe i lashed up into a backing tool
    Bing (1)
