Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#661 venkman
venkman
  • 452 posts
Posted 10 January 2017 - 07:38 PM
Just confirming everyone else is thoughts.....great, STILL make it look to easy.
Keep them coming.
#662 Van13
Van13
  • 314 posts
  • Local Club: Unknown
Posted 11 January 2017 - 01:24 PM
Amazing workmanship,wish I had half the talent
#663 Cookiez
Cookiez
  • 205 posts
Posted 12 January 2017 - 08:16 AM
Great work on the boot
Really like what & how you do things.
#664 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 13 January 2017 - 08:48 PM
Skin is now on but there was quite a bit of prep work to do first so a few pulg weld holes and pins and top coat.
Then it was plug weld time
And all knocked back
Ready to fold over
First pass
And the finished folds
And the finished article although there is more tweaking and the all important gapping to do
#665 pete l
pete l
  • 1,368 posts
Posted 14 January 2017 - 08:46 AM
How are you going to do the gapping Neil ? Mine is exactly the same as yours, weird gaps all around.
Pete
#666 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 14 January 2017 - 09:18 AM
Pete
Pete I will be using welding rod, the same as I used on the doors.
#667 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 14 January 2017 - 11:18 PM
Continued with the panel gapping today
Welds knocked back
I add some weld to the l/h side rather than welding rod and ended up with this
And all primed for the time being
Needs some final tweaking here and there but basically ready for filler.
#668 venkman
venkman
  • 452 posts
Posted 15 January 2017 - 09:16 PM
Damn that's good, are you the "saint of patience" don't think I have your skill, definitely not the patience!!
It's going to be a perfect mini when finished!!!!
#669 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 January 2017 - 10:36 PM
Not sure about perfect as there are a few things I would do differently but that's life. The hard bit is coming up and that's paint prep and paint.
#670 MacGyver
MacGyver
  • 1,027 posts
Posted 16 January 2017 - 07:01 AM
Hello Neil, brilliant work on this! 😎
Are you filling the little gaps between panel and welding rod? Or will it not pose a problem? Looking forward to doing this on mine too. Thx!
Ben
Edited by MacGyver, 16 January 2017 - 07:01 AM.
#671 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 16 January 2017 - 07:02 PM
Ben I will be filling the small gaps. Some with weld the rest with filler.
#672 jamesquintin
jamesquintin
  • 1,017 posts
Posted 17 January 2017 - 08:04 AM
Is there any particular reason you used lots of plug welds to hold the skin on before folding the edges over..? At the factory they had a spot weld under where the hinges go, and two right in the middle near where the numberplate holes would go.
(I've got to do this to mine soon)
Q
#673 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 January 2017 - 09:01 AM
Q
It gives it all a bit more rigidity plus my skin had more spot welds than just the ones under the hinge and on the lower frame.
#674 mattmiglia
mattmiglia
  • 515 posts
Posted 17 January 2017 - 01:54 PM
Are you painting the shell your self? Gaps are awesome!
#675 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 January 2017 - 04:32 PM
Yes I will be doing all of it. Going to wait though for warmer weather although I will be spraying Gravitex next week after sealing.
