Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#631 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,037 posts
  • Name: Neil
Posted 06 November 2016 - 10:29 AM
This is amazing! Are you still putting R1 power in it?
I was going to to originally but now going down 7 Port route with fuel injection from Specialized Components. We are hoping to go R1 on my lads car.
#632 venkman
venkman
  • 452 posts
Posted 06 November 2016 - 03:52 PM
Today was remove the inner A post stiffener just to see what the damage was.
So out the old bits
and this was the state of the inside of the A post
Rusty as hell so without resorting to spending another £70+ it was time to brush up on my fabrication skills
So new stiffener slaved in place
And the first repair piece in place
Followed by the rest of the sections
Overall very happy with it, just a few final tweaks and cleaning up and it will be finished.
Right I'm a bit stuck!!
I'm putting in the door step up to bottom of windscreen repair panel and a new A post stiffener. Know if I clamp in the frame and offer door up it all looks good. My problem is were to weld the stiffener,looking at yours it looks like it's right up to the frame were as mine is close at bottom but 1/4" away at top.
Do you just weld the A post to the frame and then bend it out to fit door?? Hope this makes sense.
Oh there are no holes from the inner wing for me to use to line up with. You make it look easy!!!
#633 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 06 November 2016 - 04:27 PM
The inner A post stiffener spot welds to the A post and also the flitch panel as well.
#634 venkman
venkman
  • 452 posts
Posted 06 November 2016 - 05:24 PM
Thanks got that bit worked out, do you just weld it in were it fits (as its shaped at the bottom) or need to do it with door and Mark up then weld.
Sorry about hijacking your thread
#635 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 06 November 2016 - 06:50 PM
No probs, i left enough of the outer A post to act as a guide as the inner is shaped to follow the outer. There should be no need to bend anything.
You could trial the door if it helps but i did not and had no issues with alignment.
#636 venkman
venkman
  • 452 posts
Posted 06 November 2016 - 07:14 PM
So if I line up the door catch/stop in centre of hole then plug weld should be good! Thanks Ian
#637 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 06 November 2016 - 07:15 PM
Tack weld it all together if unsure, trial fit it then if its good weld it in place.
#638 pete l
pete l
  • 1,369 posts
Posted 07 November 2016 - 08:46 AM
Neil, what do you do to protect the steel inner box sections ? the rear of all these panels that you make out of steel, once welded in, how do you get to the rear of them to apply paint ?
#639 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 07 November 2016 - 08:49 AM
Pete, before I weld anything in place I apply epoxy primer and paint it weld through Zinc rich primer. Wherever possible afterwards I then force in more topcoat.
#640 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 18 November 2016 - 07:32 PM
Upwards and onwards front wings prepped for fitting
And clamped in place ready for burning metal
And the first welds
A panel to wing done and dusted
Just the internal welds left to do and around the headlamp surround.
#641 Marco1972
Marco1972
  • 822 posts
Posted 18 November 2016 - 09:41 PM
Looking good Neil
How much left to do ?
Will it see the paint shop this side of Christmas
Mark
#642 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 18 November 2016 - 09:54 PM
Looking good Neil
Mark
The drivers wing to finish, passenger one to fit, bonnet to sort out, boot lid to reskin, seat pan stiffener to fit, an absolute stack of seam sealing, floor priming, Gravitex spraying so in a word.............No.
Sometime in the new year i feel Mark.
#643 Marco1972
Marco1972
  • 822 posts
Posted 21 November 2016 - 03:12 PM
Lol
You've just made me realise how much I've still got to do
I'd planned to have mine painted by now but my ( ready by date ) just keeps on slipping
Looking great tho Neil
Keep it up mate
#644 sonikk4
sonikk4
  • 16,037 posts
  • Name: Neil
Posted 21 November 2016 - 06:02 PM
R/h wing is finally welded up and dressed including the stiffener between the wing and A panel. Once the car is back on the spit then some final dressing and tweaking will be done.
#645 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 21 November 2016 - 06:21 PM
Do you always just use the MIG? I wished I'd had access to a spot welder when I was doing the bodywork on the Mini, would've saved a lot of hours work. Also I see that you welded the small strengthening panel under the scuttle to the wing, when I did this area I feared welding here as I felt it would've burnt off any paint I'd applied on the inside and possibly had a rust issue, so I bonded this area together. I now wished I'd welded it and filled the corner of the scuttle with cavity wax. On the passenger side the paint on the seam with the wing and scuttle has a small crack from movement. The other side is fine however. I'll sort it when I respray her in a few years!
