Project Paddy A Long And Slow Rebuild.
1096 replies to this topic
#541 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,079 posts
  • Name: Neil
Posted 14 April 2016 - 05:52 PM
Did a trial fit of the front end just to see if things were off and all in all not too bad considering the subframe was not fitted.
Some tweaking and trimming will be needed but until the subbie is slaved in then there is no point.
I did a double check of the new scuttle and found the windscreen flange differed by 2mm left to right so that had to be trimmed off
Then it was onto the r/h lower flitch returns attaching to the toeboard. When i first bought the car it came with oversills and there was some corrosion to the lower flitch as well so that was repaired then. However looking at it again today it was not good enough so it was time for a new flitch section.
This will go in once i have fabbed up a new section for the other part of the lower flitch where it runs up to the lower bulkhead
#542 Daz1968
Daz1968
  • 2,058 posts
Posted 14 April 2016 - 09:13 PM
Looking very good,
#543 ger
ger
  • Just Joined
  • 233 posts
  • Local Club: M4 Minis
Posted 14 April 2016 - 09:39 PM
Lovely job.
#544 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 14 April 2016 - 09:41 PM
Looking very good,
Lovely job.
Cheers folks. :D  :D
#545 WPD
WPD
  • 85 posts
Posted 15 April 2016 - 12:29 PM
looks great, coming along nicely
#546 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 16 April 2016 - 06:02 PM
A bit more on the fwd lower flitch done.
New sections fabbed and pinned in place
[/URL]
and welded in place
and ground flush, the inside needs to be dressed back later
#547 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 16 April 2016 - 10:09 PM
Very nice
#548 Marco1972
Marco1972
  • 822 posts
Posted 18 April 2016 - 07:21 AM
Great work bud
Got to ask .... How did you get the curve in that bottom piece ?
Looks great .... As always
#549 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 19 April 2016 - 08:19 PM
very, very nice work. I love the updates on Paddy
#550 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 20 April 2016 - 03:33 PM
Great work bud
Marco the curve was a royal pain as its almost a compound curve which i could not properly replicate with my shrinker and stretcher. In the end i did use two sections, the straighter one was no problem but the second one i did a series of cuts and then formed the curve. Once that was correct i then used a piece of flattened copper as a backing piece so i could fill in the expanded cuts. Linished it all back then welded them in place.
#551 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 23 April 2016 - 09:21 PM
On with more repair sections to the toeboard and floor area.
Flitch repair section pinned and clamped in place ready for welding up
#552 Marco1972
Marco1972
  • 822 posts
Posted 25 April 2016 - 10:59 AM
Fantastic work mate
I've got to get me some of those skin pins .........
Mark
#553 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 07 May 2016 - 09:35 PM
Flitch done and dusted
Then it was onto the remaining clips on the floor so before removal
and what was hiding under them
All rust coutout
new sections tacked in place
Ground flush
New clips fitted
#554 sonikk4
sonikk4
  • 16,079 posts
  • Name: Neil
Posted 10 May 2016 - 08:31 PM
Sill is on now
Then it was off with the drivers door skin. Something did not look right
So the inside of the frame got some Bilt Hamber action as it was only surface rust
and a coating of Epoxy primer
The skin got prepped while i waiting for the De Ox to do its stuff
So i have sheet steel in the car which i will fold at work to repair the bottom of the door and the sides and then get the remainder of the nasty stuff replaced. Never ending. The skin had been replaced by the looks of it unless they braised the doors at the factory. Real shame there was nothing at all paint wise on the folded edges.
#555 Daz1968
Daz1968
  • 2,058 posts
Posted 10 May 2016 - 08:53 PM
Original mk1 doors are brazed there, so every possibility later ones are, looking good though
    Bing (2)
