Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#511 minimuk
minimuk
  • 1,946 posts
Posted 08 February 2016 - 07:49 PM
Surely you are Master Neil by now.....
#512 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 09 February 2016 - 06:53 PM
More holes appeared today in Paddys floor
and so with the splicing of some of Project Erm's DNA
this happened
including the new tag
then it was onto the power cable conduit, it looked bad and this was what was lurking
 so it was a serious case of wire brushing and linishing to get this
there is some minor pitting but that will get treated tomorrow. Then this needs to come off to see if there is anything hiding as well.
#513 wingnut
wingnut
  • 463 posts
Posted 09 February 2016 - 07:06 PM
Fantastic work!
#514 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 10 February 2016 - 07:15 PM
Right off with the seat belt mount and yup it was crusty
so a bit of fabrication later i ended up with this
and welded back in place, happy days
and the results of yesterdays efforts
So thats it for a while, i know a couple of parcels are arriving tomorrow so hopefully i can complete the l/h inner wing and then move onto the r/h side.
#515 Macker2
Macker2
  • 14 posts
Posted 10 February 2016 - 09:41 PM
Really enjoy reading this thread. Great work
#516 minimuk
minimuk
  • 1,946 posts
Posted 10 February 2016 - 11:03 PM
nice bitta metal playing Neil,....only perfect will do ;D
#517 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 10 February 2016 - 11:20 PM
Cheers Michel
#518 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 20 February 2016 - 07:39 PM
Battery cable conduit fitted
However before it was fitted i had to take a big chunk out of it
Then it was on with the new rad shroud so pinned in place
Welded in place
Welds dressed back and epoxy primed
#519 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 February 2016 - 07:34 PM
So it was on with the other side so started with this
and ended up with this
rust and more rust, but it did not stop there
reinforcing gusset was bad behind and then the crossmember looked like this
so that had to go as well
so new one made.
so while i was at it the top steady bracket looked a bit crusty so that came off and you more rust behind that
Now removed and the new upper section tacked in place. There is still more of the crossmember to replace but little steps needed here.
And a random look inside the crossmember where the twin bolts go through
#520 Daz1968
Daz1968
  • 2,058 posts
Posted 27 February 2016 - 07:49 PM
Good work , have my front to tackle next so may have to do similar. Looking at this helps a lot thanks
#521 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 February 2016 - 08:39 PM
No probs, still more to do as there is stuff lurking in the r/h edge of the heelboard to inner wing.
#522 Carlos W
Carlos W
  • 10,114 posts
Posted 27 February 2016 - 08:49 PM
The amount of rust lurking is scary
#523 RON1966
RON1966
    Just On Tickover
  • 9 posts
Posted 27 February 2016 - 09:03 PM
An exceptional amount of information in this build that I will need in due course. Attention to detail and the quality of workmanship is second to none especially the quality of the welding. It scares me though of the amount of hidden rust in what was a very clean and tidy looking clubby. Superb. '
#524 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 February 2016 - 09:14 PM
I do believe if he had not lived in a bodyshop for 10 years then there would have been serious issues bodywork wise so i'm grateful for the rust there actually is.
Ultimately i do not want to have to do this all over again so its a once only all out attack. If its ever so slightly suspect then its off. I'm glad the build is helping other peeps.
#525 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 28 February 2016 - 07:28 PM
Well the day started off well, managed to weld in the new section of crossmember and was in the process of cleaning up the welds when our workshop neighbour popped round. Wanted his mower blade sharpening again so off it came and sharpened it up. Fitted and was just doing the final tweaking up when the ratchet teeth failed and i took a quite violent blow to my knuckles. Whipped the nitrile glove off and it was blood time. BUGGER!!
I had taken off the first joint knuckle skin on my index and middle finger plus a small cut on the third finger. Mucho blood so numerous plasters and masking tape helped to stem the flow. Put another glove on just to enable me to clear up and flash some epoxy primer over the crossmember. So ended up with this for today
Properly dressed now and the repair part way through dressing the welds
