Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#451 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 29 September 2015 - 06:27 PM
Another quick trial fit to make sure the quarter panel fitted before welding commenced and all is good
So on with the welding, first off was the arch closeout, in place
then with the inner sill stiffener welded in place as well
Then it was in with the companion bin
Quick clean up of the inner sill and some paint
#452 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 06 October 2015 - 06:43 PM
Today was a day of sealing up stuff before fitting the quarter panel so lots of taping later
Then it was on with the sealant and primer
#453 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 07 October 2015 - 06:31 PM
Splashed a bit of paint around before the quarter panel install
Drilled the plug weld holes and epoxy primed the quarter panel
And found that the epoxy primer if sprayed on the recently applied topcoat (4 weeks ago) reacts. Bummer.
#454 Pauly
Pauly
  • 4,213 posts
Posted 07 October 2015 - 06:54 PM
Great progress!
Any tips on cutting the old inner sill off straight?
#455 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 07 October 2015 - 07:05 PM
Great progress!
Cheers, i basically undercut the old sill by an inch or so or in my case with Paddy half an inch. So i make sure the new inner sill is reasonably straight along the edge and then measure from the edge of the flute to the edge of the sill. Then transfer that measurement over to the old sill and undercut that measurement.
#456 Pauly
Pauly
  • 4,213 posts
Posted 07 October 2015 - 07:57 PM
I had a feeling it would be something like that, just me being thick haha.
Cheers!
#457 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 October 2015 - 06:54 PM
Finally got the l/h rear quarter on and happy with it
Now at this point in time it was time to turn Paddy around so did that and splashed some Epoxy primer on to the welded seams.
Next on the list was remove the A panel to see what the flitch return was like after a couple of years and i realised it had to go. Having a close look at the hinge mounting points showed a bit of pitting so it had to go
And then it was fab a replacement section so started with this
And ended up with this
That will get fitted next week, in the meanwhile it was time to investigate the scuttle. First viewing it looked ok but there was something lurking
Cleaned the paint off and it started to show a bit more
The flange was cruddy but there was more to come
So for all of you peeps who only see whats on the surface well here's what reality is like
Now to top it off the closeout was just as bad
It was all going anyway but it just goes to show you what can be hiding. Please bare in mind though this is original metal 41 years old.
So while i was at it i stripped all of the underseal off the inner wing
Not too bad and again for a 41 year old car very good but i'm in two minds whether to replace the front of the inner wing. There is  quite a bit of pitting and even after using Bilt Hambers finest its 50 50. However the good news is the shock mount is virtually pristine
so after some stripping and surface rust removal i ended up with this
And with the flitch return off i decided to crack on with the door step so thats in the process of being tweaked and fettled ready to fit
#458 JayBox
JayBox
  • 150 posts
  • Local Club: Mendip Minis
Posted 16 October 2015 - 02:10 PM
Love it. Such a clean project. So good to see it come together. Wish I had the patience for it.
#459 grahama
grahama
  • 2,442 posts
Posted 16 October 2015 - 02:46 PM
Excellent work as always
#460 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 October 2015 - 08:26 PM
Cheers for the comments folks, well it was back on with the doorstep and it went something like this
and even the workshop shovel got some love as well
#461 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 October 2015 - 06:59 PM
Back on with the A post repair and ended up with this
So once that was ground down i did a quick check of the door fit and it was quite good
Will have to sort this gap out after the door has been reskinned
Then it was on to the top of the flitch. There was a bit of rust lurking so after a bit of cutting this was the result
And to add insult to injury there was a lot of surface rust around the bonnet hinge mount so that will have to come off
AND to add more fuel to the fire there was absolutely no paint at all inside the windscreen pillar area. Luckily its minor surface rust and will treat easily. The rust that was there was so minimal for 41 years. That will get sorted next week.
So it was on for some panel fabrication, this will get welded in once the surface rust is sorted.
#462 Covert
Covert
  • 526 posts
Posted 24 October 2015 - 05:21 AM
Looking awesome as always neil
#463 FlyingScot
FlyingScot
  • 2,664 posts
Posted 24 October 2015 - 07:01 AM
Some great welding and fabrication there. The shell will be better than new when you're done.
FS
#464 alchall
alchall
  • Just Joined
  • 604 posts
Posted 12 November 2015 - 03:51 PM
Just read your feature in mini magazine, hows it feel to be famous(ish)? :-)
#465 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 12 November 2015 - 04:20 PM
Is it out???, not seen it yet. Is it Decembers edition.
