Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#436 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 03 September 2015 - 09:34 PM
looks brilliant mate
Cheers, i'm pleased as punch with it, will trial fit the door again tomorrow just to double double check it but nothing moved so should be golden. I hope i dont have to do this with the other side.
I thought i would get away with mine on the other side after doing more or less the same as you have just done.
i was wrong.............. O_O
Repair looks ace though
#437 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 04 September 2015 - 06:53 PM
Cheers Ben,
on with the flitch repair today so basically ended up with this, panel pinned in place
And welded in place and ground down
The top needs a new section fabricating so will sort that out probably next week. Then that will be out of the way.
Did trial the door again and some persuasion was needed on the A post to move it fwd slightly. No point in going mad at this point in time as i need the car off the spit before i gap the doors properly. As long as its roughly in the hole then i can go from there.
#438 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 08 September 2015 - 08:21 PM
Awesome work as usual Neil!
#439 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 11 September 2015 - 06:32 PM
Cheers Dan,
well it was time for the outer sill but first thing i had to do was rescue the old jacking point i had fitted previously.
And after a bit of cleaning up and careful positioning its now in place
More than strong enough and it will get used as it was before.
So a bit more prep was needed on the outer sill, some redundant holes needed to be filled first
Happy with that so a bit of epoxy primer and topcoat later
and the inner sill got some more of the same
Back to the workshop tomorrow as Paddy has a Photo shoot.
#440 rich2
rich2
  • 351 posts
Posted 15 September 2015 - 12:15 PM
Nice! Going in a magazine? I'll be looking out for it!
#441 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 15 September 2015 - 08:33 PM
Should be in Mini Mags" On the job section "in two months time.
#442 ribz0
ribz0
  • 188 posts
Posted 18 September 2015 - 10:32 AM
Awesome work Neil!!
#443 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 21 September 2015 - 07:26 PM
Inner sill time, l/h side so before
inner sill off
and here it is
#444 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 September 2015 - 06:32 PM
And in with the new sill, well sort of, tacked in place
But a fly in the ointment, there floor pans do not match, had the same issue with Wills Mini Special
A job for tomorrow i feel, anyway the rest of it welded in
and ground down
a bit of hammer and block work to do to finish it off.
#445 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 September 2015 - 07:29 PM
coming on well Neil
#446 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 September 2015 - 07:37 PM
coming on well Neil
Cheers Ben, got a bit of work to do with the front of the floor pan where it lips over the toeboard. There be rust lurking between so i will chopping sections out of both.
#447 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 24 September 2015 - 04:39 PM
Same as I did mine. I thought you overlapped your floor repairs last time?
#448 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2015 - 06:02 PM
I did on Wills Mini Special. One thing doing it for yourself, another doing it for someone else. He did get the option though. It was actually cheaper to joggle the floor rather than butt weld.
#449 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 September 2015 - 08:21 PM
Sorted the front of the floor pan and quite happy with it
Quick splash of epoxy primer
Leaving the rest of the welds at the front until i have sorted the front of the floor pan. Everything will have another dose of hammer and dolly work before a skim of filler.
#450 Daz1968
Daz1968
  • 2,058 posts
Posted 24 September 2015 - 08:28 PM
Looking really good
