Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#421 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 August 2015 - 07:55 PM
Cheers for the comments folks,well it was quarter panel day today so started welding the beastie in
Should have it fitted tomorrow and ground flush.
#422 mk1leg
mk1leg
  • 9,343 posts
Posted 19 August 2015 - 09:23 PM
WOW what a build.........keep up the fantastic work......
#423 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 20 August 2015 - 06:44 PM
So on with the quarter panel welding to day and 5 hrs later it went from this
to this
Very please and minimal filling to do.
#424 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 20 August 2015 - 06:48 PM
Looks superb mate.
Did you spot weld any of it?
#425 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 20 August 2015 - 07:04 PM
Looks superb mate.
Nope all plug welds, still cant get to grips with my Spot welder.
#426 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 21 August 2015 - 07:37 AM
Excellent finish there.
#427 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 22 August 2015 - 06:51 AM
Top work these its looking great :)
#428 Marco1972
Marco1972
  • 822 posts
Posted 23 August 2015 - 10:05 AM
Looking good Neil
Those door steps look great just about to fit mine that I had off you
Have you any more detailed pics of the fitting process just noticed that one end of the steps is a slightly thinner diameter than the other
Is this the front end ?
Cheers mate
#429 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 August 2015 - 10:11 AM
Looking good Neil
Cheers mate
Hi Marco one end is thinner but off the top of my head I cannot remember which end. No more detailed pics though. I think the narrower end is the front but you can check that out when you come to fitting it.
Don't forget you will need to cut the ends around to get the curvature correct. I cut on the fold line and notched the return where it attaches to the inner sill to do this.
#430 Marco1972
Marco1972
  • 822 posts
Posted 23 August 2015 - 03:31 PM
Cheers Neil
Will do - off on holiday next week for a well earned break so it's top of my list when I get back
Cheers bud
#431 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 26 August 2015 - 06:51 PM
Moving fwd literally so it was a quick trial of the door to make sure its fits which it did and then onto the A post.
First thing was to get the replacement flitch panel to line up. So after a bit of tweaking the lower hinge holes were relocated to the correct place and the top of the A panel return was sectioned to get the correct contour.
Right happy with that so onto the rusty bits, took a chunk out of the scuttle and removed the closeout just to make sure i have got the rust mapped
Then cut out the flitch section to find this
Not good and caused by this
A bloody great chunk of foam fitted at the factory. Just something else to deal with tomorrow
#432 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 August 2015 - 06:17 PM
Today was remove the inner A post stiffener just to see what the damage was.
So out the old bits
and this was the state of the inside of the A post
Rusty as hell so without resorting to spending another £70+ it was time to brush up on my fabrication skills
So new stiffener slaved in place
And the first repair piece in place
Followed by the rest of the sections
Overall very happy with it, just a few final tweaks and cleaning up and it will be finished.
#433 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 September 2015 - 07:27 PM
So on with the repairs, first thing to do was add some extra bracing as i will be cutting out the section where the main bracing is welded to.
Then out with the rotten section
New section cut to size
And this is the stiffener section for the dash rail
Repair section welded in place
And with the A post fully welded in, ground down and buffed up
Very pleased with it.
#434 Carlos W
Carlos W
  • 10,114 posts
Posted 03 September 2015 - 07:38 PM
looks brilliant mate
#435 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 September 2015 - 07:40 PM
Cheers, i'm pleased as punch with it, will trial fit the door again tomorrow just to double double check it but nothing moved so should be golden. I hope i dont have to do this with the other side.
