waow ! you have some great skills ! but i did not expect all that work on your lovely little clubby !
Project Paddy A Long And Slow Rebuild.
#406
Posted 18 July 2015 - 07:19 PM
#407
Posted 09 August 2015 - 07:37 PM
Been a little while but got on the with the doorstep, so old one off
and new one on
bit of final fettling to do but other than that its done.
The next fly in the ointment though is the A post, its not looking too happy
so more monies spent but while i was at it i ordered a new scuttle closeouts and a boot skin. most of its here
So the plan is to cut the other damage out on the flitch area then remove the A post stiffener, check to see if that is bad then repair the outer a post and nail it all back together again. But before all of that i might just weld in the quarter panel first. Its never ending. Oh and the flitch damage plus a newly found hole in the a post.
#408
Posted 09 August 2015 - 08:13 PM
Are they those steps you had made?
#409
Posted 09 August 2015 - 08:37 PM
Yes they are Ben, made from 1.2mm steel and really good. Just need to form the curved ends if required. I cut mine slightly at each end to get the curve.
#410
Posted 09 August 2015 - 09:04 PM
Are they available or are these just for you?
They look good and i expect cheaper than heritage step/posts
#411
Posted 09 August 2015 - 10:52 PM
Andy
#412
Posted 10 August 2015 - 08:22 PM
I do have a spare pair as it goes Ben
I can vouch for how good those door steps from Neil are. I was lucky enough to get hold of some, and just about at the point of fitting one to the drivers side.
. . Excellent update Neil .
Andy
Cheers for that Andy glad they helped.
#413
Posted 10 August 2015 - 08:43 PM
I might be interested in one if it can be arranged?
I need to slice a bit of the flitch off to see what the A post section is like before i decide if i need the whole a post/step or just the step
#415
Posted 12 August 2015 - 08:21 PM
#416
Posted 12 August 2015 - 08:27 PM
Excellent work as usual, Are you just using rattle can to spray the companion bins etc.
#417
Posted 12 August 2015 - 08:52 PM
Top work as always Neil
Cheers Dan
Rattle cans it is although these are nearly £18 a pop as i have had these mixed.
#418
Posted 13 August 2015 - 01:18 PM
Lots of lovely new panels........ ..!
Nice shade of blue too!
#419
Posted 18 August 2015 - 03:53 PM
Love this topic, getting lots of inspiration from here.
#420
Posted 19 August 2015 - 03:48 PM
The progress is amazing....well done so far
7 user(s) are reading this topic
Bing (4)
