Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#376 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 June 2015 - 06:37 PM
Back end of the car is now complete bar a skim of filler on the rear valance.
Closeouts all sealed internally
Heavily Zinc primed
And valance fitted.
#377 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 June 2015 - 06:59 PM
Final bits done at the back of the car today. First thing was to finish off welding the gaps in the rear valance closeouts
This is the l/h one but the right hand side was the same
Gap welded up
R/h side done as well
Battery clamp captive nut welded in place
and then it was onto the fuel pipe holes salvaged from the old boot floor
Welded up the last of the skin pin holes so all thats left to do now in the boot is the fuel tank bracket and captive nut. This will be done later on.
#378 wingnut
wingnut
  • 463 posts
Posted 22 June 2015 - 07:52 PM
Im loving your work
#379 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 22 June 2015 - 08:07 PM
Im loving your work
Cheers :D
#380 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 23 June 2015 - 12:22 PM
Looking good. Nice touch with the fuel line hole.
#381 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 23 June 2015 - 07:24 PM
Down to the nitty gritty of the inner sills. First thing was to remove the Ziebart coating that's been on for 41 years. So the r/h side of the floor done.
and the l/h side still to do
this then highlighted several things, firstly the steering rack mount, this is quite crusty on the toeboard area so that will have to come off in the very near future
and then this lower flitch return has started to bulge so that will need to be sorted.
So off came the inner sill
So all ready for the new inner sill. One small issue it wont go in due to the returns on the heelboard and flitch so had to do this
not what i really wanted to do but needs must.
#382 CBJ805T
CBJ805T
  • 438 posts
Posted 24 June 2015 - 11:42 AM
Gap welded up
Hi Neil,
I'm in the process of carrying out the same job on the boot floor. Would you be able to measures the diameter of the 2 fuel pipe holes? My mini is cursty in that area and so I can't be sure of the dims.
thanks
Chris
#383 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 June 2015 - 03:38 PM
Hi Chris I will do so tomorrow
#384 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 June 2015 - 08:21 PM
So after a bit of trimming and faffing about the inner sill is in place all ready for final welding tomorrow.
and tacked in place
and just a quick check to ensure the subframe mounts are still in alignment
#385 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 24 June 2015 - 08:24 PM
Nice work Neil!
#386 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 24 June 2015 - 08:26 PM
Cheers Dan, have you just renewed your TMF+ by chance??
#387 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 24 June 2015 - 08:29 PM
Yeah it auto-renewed today!
#388 MINIMADrt
MINIMADrt
  • 465 posts
  • Local Club: none at mo
Posted 25 June 2015 - 05:59 AM
Good job I love looking at this thread. Just wish I could turn out this good haha
Good job
#389 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 25 June 2015 - 07:22 PM
Inner sill in and ground flush both sides. Just a few bits to tweak at the heelboard end and toeboard. That leaves the heelboard subframe bracket to weld in place.
flashed over with epoxy primer
and the inside
a few hours should finish that off
#390 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 25 June 2015 - 07:25 PM
Did you do a joggled join or is that butt welded like mine?
    Google (1)
