Project Paddy A Long And Slow Rebuild.
1090 replies to this topic
#361 Covert
Covert
  • 526 posts
Posted 17 May 2015 - 08:01 PM
Any pics of this tang fellas ?
#362 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 17 May 2015 - 08:09 PM
In this picture if you look at the inner section of the arch at the rear there is no tang
and now in this one you can see where i have added it, its right next to the mole grips
#363 Covert
Covert
  • 526 posts
Posted 17 May 2015 - 08:11 PM
Thanks matey
#364 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 May 2015 - 08:14 PM
No worries. The New boot floor does not have the extra piece on it either, well certainly not as much. Later pressing i suppose. Quite a few differences from the older type.
#365 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2015 - 08:43 PM
What's it for Neil?
#366 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 May 2015 - 08:45 PM
Basically on the older floor pan there was a larger return there but on the later MPI floor pan which is the only one available now there is not. Maybe extra strength for the subframe mount??
#367 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2015 - 08:47 PM
Ill have to look into that then.
I should probably have them on mine and i want the details correct.
Ben
#368 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 17 May 2015 - 08:53 PM
Ben
Here's the old arch and you can see it clearly.
#369 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 17 May 2015 - 08:55 PM
so i guess you just made up a small extension and seam welded it to the arch then?
My passenger arch is still intact and on the car so ill take a close look tomorrow to get a better idea.
I'm glad i saw this now as i would never have known..
Ben
#370 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 18 May 2015 - 06:33 AM
I only noticed it on mine as I was planning to fit mud flaps but there is nothing to fix them to.
#371 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 27 May 2015 - 03:27 PM
Well it was off with the front today today so this all happened.
So quite a bit to do but not seriously bad luckily enough although the scuttle is toast
#372 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 27 May 2015 - 04:50 PM
I was getting so confused about the tang you were mentioning, but I have an MPI so that would explain it. Finally an advantage to having to worst quality steel and build quality. Although maybe on that note I should add it...
#373 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 18 June 2015 - 07:26 PM
So back on the case again after a week abroad.
Time to finish Paddys backside before i hit the inner sills so it was onto the rear valance closeouts and rear valance.
Valance clamped in place
Closeouts added
Plug weld holes drilled and ready to weld
And welded in place
The other side is prepped ready for welding tomorrow
So if all goes well tomorrow the rear of the car will be complete bar the boot lid reskin.
#374 CBJ805T
CBJ805T
  • 438 posts
Posted 19 June 2015 - 11:51 AM
Hi Neil,
I see you are plug welding the closeout to the rear valence, which presumably you'll grind back to make it look nice and smooth. Do you know how this was done originally? did they just spot weld it and leave the evidence?
#375 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 19 June 2015 - 02:35 PM
Hi Neil,
Everything originally would have been spot welded, very little on the car would have had any seam welds.
And yep all of the plug welds will be ground back flush.
