Project Paddy A Long And Slow Rebuild.
#166
Posted 15 March 2013 - 04:48 PM
Which rubber donuts have you bought and from where? I cannot decide which ones to get at the moment as they seem so expensive!
#167
Posted 15 March 2013 - 06:39 PM
The fronts are Red spots i bought by mistake from another member on here.
These i have fitted to the front but just reading the preamble about them i may have to swap over to standard cones as i don't want to cut my new hi lo's
#168
Posted 15 March 2013 - 07:05 PM
One problem is the hubnut. Stupid thing is 34 mm so had to buy a socketfrom Halfords so also bought a rather large 34 mm spanner while i was at it courtesy of my trade card. Those and a tub of Lithium grease was only £19.99 a saving of a tenner.
Now after assembling all of that lot the Caliper fouls slightly on the hub so that needs sorting out. And as in my last post i will need to replace the new red spot cones with standard ones.
Next thing to fit is this
#169
Posted 16 March 2013 - 09:22 PM
#170
Posted 16 March 2013 - 09:24 PM
Brake set-up are looking fab wish I was at this stage .........
Cheers although its got to come apart again to swap out the cones. Need standard ones and the the red spot ones i have fitted.
#171
Posted 16 March 2013 - 09:31 PM
part of the course I suppose, aslong you are able touse the nylon nuts again all ois good....
#172
Posted 16 March 2013 - 09:35 PM
#173
Posted 16 March 2013 - 10:11 PM
Darren
#174
Posted 16 March 2013 - 10:21 PM
I know you have done little bits to paddy but he is pretty clean for a car of that age is there anything major to do on him?
Darren
Yes there is, we bought him knowing that he had had a rear end shunt which had been repaired by Stevie Wonder. Boot floor buckled, hinge panel distorted and poorly repaired and also the rear panel has been distorted but got pulled straightish.
Unless you looked carefully you wouldn't know so he will be getting a full resto including rear panel, complete boot floor, both rear quarters, new boot lid skin, rear valance, new door skins, complete front end, new inner sills (there was some pitting caused by the oversills and although not bad i know its there.)
He still does not look bad for his age (38 this year) just really needs to be done properly and thoroughly.
Going to use him for at least a year before this. been talking to my lad and may buy the 1293 hes got tucked away for Erm. I really want the R1 conversion but i have spent all of the money on Heritage panels. Such is life.
#175
Posted 16 March 2013 - 10:41 PM
#176
Posted 16 March 2013 - 10:45 PM
Ha they are never as clean as they look ay lol. Funny you should mention an engine convention just been thinking about a 16v rover k series for mine just seems financially more bang for the buck and increased reliability
That's the thing with mini's there is always something. For the moment i will be staying A series but in the end there will be Jap bike power. Never been keen on the K series but modified well they are not as bad as people make out.
#177
Posted 16 March 2013 - 10:55 PM
#178
Posted 10 April 2013 - 05:43 PM
So from this
to this
And now back on his wheels although looking like a 4 x 4. Need to let the suspension settle for a while before i wind down the Hi lo's
Now to decide which look to go for, hubcaps and trim
or just the hubcap look
Master cylinder to fit next then a full bleed and hopefully a fully functioning brake system. That will be a job for next week when i'm off shift.
MOT is getting closer
#179
Posted 10 April 2013 - 07:42 PM
Looking good... any updates on Erm?
#180
Posted 10 April 2013 - 07:55 PM
just the hubcap in my opinion
No none really. Just waiting for the warmer weather so i can respray inside the roof gutters before i cut the roof out and fit the carbon fibre one. Oh and buy a pneumatic air shears to cut the roof section out.
I'm torn between trim or no trim on the wheels and i am also things about fitting some stainless steel round hub caps instead of the clubby ones. We shall see.
Bing (1)
