Replacing The Piston Rings
Posted 16 March 2011 - 04:22 PM
Thanks in advance.
Posted 16 March 2011 - 05:29 PM
Posted 16 March 2011 - 08:40 PM
Posted 16 March 2011 - 09:24 PM
Here's a link from an earlier thread...... http://www.mini.or.a.....9;69 full.pdf
Edited by bmcecosse, 16 March 2011 - 10:37 PM.
Posted 16 March 2011 - 11:34 PM
there is no way in hell that is easier than lifting the box with the block.
Posted 16 March 2011 - 11:44 PM
Posted 17 March 2011 - 08:45 AM
Wouldn't you also need to remove the clutch housing to pull the block, thats a fiddle right there whilst in the car. ???
Posted 17 March 2011 - 08:53 AM
id go buy
Full engine gasket set
big end shells
small end shells
piston rings
timing chain
cam followers
oil pump
water pump
all lock washers
then
id clean everything up, have the cylinders honed and then rebuild it all back up
Posted 17 March 2011 - 09:38 PM
Posted 17 March 2011 - 10:23 PM
Thanks for the replies, it seems doable at not too much of a cost. If I am taking the engine apart, are there any cheap and simple modifications I can to to help increase power a bit without effecting MPG or reliability?
If you increase the power you will use more petrol.
The best things to improve a 998 are a better gas-flowed higher comp ratio head, better cam (say a Kent 266) and an improved inlet and exhaust system. Anything less than that any you'll not notice too much improvement, the key being the opening up of the head tracts and combustion chamber shape.
