BMW One Diesel
2003
I drove from Newcastle to Liverpool at the weekend, was doing 75mph, steady, until after about an hour I noticed the internal heating was no longer blowing out hot air, but cold, and the water temp was in the red, I slowed down to 65mph and the temp went back to normal, after a further 30 minutes, it began to rise again, so I came off the motoway looking for somewhere to pull over, the temp went back to normal and stayed there, (I was expecting that slowing down, changing gears around the doors, stopping and starting would have increased the temp, instead of decreasing it!?!) Anyway, I couldn't find anywhere open to check the coolant, so carried on a bit further on the motorway, again as soon as I did this the temp went up into the red. Eventually I did find services that were open, the coolant level was very low, (this car had just had a service and MOT approx a week ago, and there was no water leaking underneath or from any part of the engine that I could see, there is no white goo under the oil cap, or any issues I could see with the engine, radiator or hoses, etc). After adding around a litre or more of water, I then started travelling again, and for around 40 minutes the car was fine, 75mph ish, but after 45 mins the overheating started again, and whenever I slowed down or brought my revs under 2000rpm, the water temp went back to normal, but then it started to rise a bit again just before entering Liverpool, as soon as I got into the city, and again started changing gears, stopping and starting, the temp went back to normal and stayed there?!?
The next day, I topped up the water, started her up and watched underneath for any leaks, there were none. Nor was there any steam or water coming from the exhaust. The car seemed fine again, the issue is, that when on a motorway for an extened period of time, for some reason the coolant seems to get used up rapidly causing the car to overheat, however slowing down, or even stopping the car cools it down.
Anyone had anything similar or any ideas what this could be? - I don't think head gasket, as I would have thought the temp would stay up and get worse around lower gear changes and stopping and starting, can't see any leaks either, slightly confusing....
All standard parts...
Thanks..
Edited by gmulvaney, 15 March 2011 - 06:05 PM.
