The point of dry decking isn't to stop the head gasket failing, it's to reduce risk through coolant losses or hydraulically locking the engine and to better control cooling the head. The amount of the oil going through the head and the viscosity means it won't bother the engine during a head gasket failure.
Dry decking stops combustion gases leaking into the cooling system in the event of blown head gasket, and also stops coolant leaking into the bores and then into the gearbox(sump). The only oil flowing through the head is that which feeds the rockers, and that hole isnt blocked off. The chances of this oil leaking into a cylinder is unheard of. Dry decking offers constant coolant temperature throughout the head and block, thus eliminating local area overheating. If a head gasket blows, it will only allow combustion gases to escape either between cylinders, or out of the engine itself.No mess when changing gasket!!!!!!!!!!! Works great for me on my 970!
