Dry Deck Worth It?
39 replies to this topic
#16 jamiestevenbell
jamiestevenbell
  • 637 posts
  • Local Club: DCMOC
Posted 19 August 2012 - 05:52 PM
im sure med sell a dry decking kit!
#17 Wil_h
Wil_h
  • 3,244 posts
Posted 19 August 2012 - 06:21 PM
I was having heating issues with my engine using the SC 7-port head, especially number 4 (as is always the case).
I dry decked it, except I left the 3 centre water ways open. Worked a treat.
#18 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 20 August 2012 - 07:32 AM
This is a bit old, Will I'm thinking exactly the same. I like the thought of having a couple of mid-way water passages to let some of the cooler water get around the end of the head that would otherwise be only getting the hottest coolant after it's been heated by all 4 cylinders and the far end of the head.
If that makes sense. I've got a dry deck kit (hose and adapters) now so just waiting to measure up the sizes for the blanking plugs.
#19 Wil_h
Wil_h
  • 3,244 posts
Posted 20 August 2012 - 09:21 AM
Should have checked age of thread. Had been up all night working and was a bit dazed when I responded. All my plugs are just threaded bar, screwed in tight and sealed with high temp epoxy.
I've only sealed the block.
#20 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 20 August 2012 - 10:45 AM
Was it the 3 bigger holes you left open or some of the tiny vents as well Will?
#21 Wil_h
Wil_h
  • 3,244 posts
Posted 20 August 2012 - 12:00 PM
When looking at the block as fitted to the car, I left open the two centre holes at the front and the single one at the rear. The holes in my head are quite small so there was a natural restriction. Most of the flow is via the new hose.
#22 mini13
mini13
  • 3,810 posts
Posted 20 August 2012 - 04:41 PM
I put holes in my plugs to prevent any trapped air (at least thats the idea) just threaded brass plugs with a small hole. if I ever need them out to run a std head I can just tap a torx bit into them and un wind them.
#23 TopCatCustom
TopCatCustom
  • 1,134 posts
Posted 20 August 2012 - 05:20 PM
Nice, almost exactly what I had planned a while ago! Also lets some of the cooler water into the head so it doesn't all have to take the long hot route :)
#24 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 20 August 2012 - 08:40 PM
Can you dry deck an spi head, or do you need the the normal by pass type as well as the kit at the other end?
Hello?
#25 Leonrjohnson
Leonrjohnson
  • 166 posts
  • Local Club: MOCQ Far North
Posted 16 August 2014 - 01:29 AM
I did this to my 970 S engine, and dont have a problem at all, works well. No thermostat, but use a blanking sleeve and blanked off bypass tubes.
https://plus.google....2417?banner=pwa
Here is a link to my photos of the dry deck. Had to modify the bottom core plug because it is a Pre A+ block.
Edited by Leonrjohnson, 16 August 2014 - 01:30 AM.
#26 69k1100
69k1100
  • 376 posts
Posted 16 August 2014 - 02:43 AM
There is a thread floating around with some nice pictures of the Westlake mkIV head and the setup they came up with for dealing with overheating.
http://mk1-forum.net...php?f=3&t=10199
Edited by 69k1100, 16 August 2014 - 03:23 AM.
#27 Ethel
  • 25,920 posts
Posted 16 August 2014 - 10:28 AM
Hello?
I don't see why not. Google up some images, I imagine there'll be dry decked race Minis running without any heater plumbing and Metros which are very similar to SPI's.
#28 Leonrjohnson
Leonrjohnson
  • 166 posts
Posted 18 August 2014 - 07:39 PM
I have dry decked an AEG163 as well as a 12G940 with no trouble. Fitted a blanking sleeve in place of a thermostat in both of them, and blanked off the bypass in both head and water pump. Works a treat.
#29 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 19 August 2014 - 02:30 AM
Would that not be a bit of a wasted effort? Surely the gasket can still fail between head waterways and an oilway or a bore?
#30 69k1100
69k1100
  • 376 posts
Posted 19 August 2014 - 10:18 AM
The point of dry decking isn't to stop the head gasket failing, it's to reduce risk through coolant losses or hydraulically locking the engine and to better control cooling the head. The amount of the oil going through the head and the viscosity means it won't bother the engine during a head gasket failure.
