1098-100 = 998 Rebuild!
#31
Posted 15 March 2011 - 10:20 PM
#32
Posted 15 March 2011 - 10:34 PM
My BIGGEST pointer is when you get a beeter cylinder head, try and source an unleaded head as an unleaded conversion will cost £200+
Half my rebuild cost has been machining work
I have a build thred in here called '1275 Eating 998' it may be of use to you and give you ideas, best of luck, I WILL BE WATCHING
#33
Posted 15 March 2011 - 11:11 PM
#34
Posted 15 March 2011 - 11:16 PM
Nothing wrong with that. You can make a 998 go like ****
Mines a 998, Stevee on here has a 998 street sleeper topic on here with alot of posts and ideas in it. Liiarge is building a 998 engine and theres another thread around on here by Racer Pete or PhillipGCaldwell with 998 engines being used to their max!
Good idea for a 998 if you want a moderate road car that goes well would be to use a stage 1 kit, 12g295 cooper head, HIF38, 44 carb or Twin HS2's combined with a SW5-07 camshaft.
This will give you alot of torquey power rather than a revvy racer. Nice traffic characteristics and an idle which is nice and driveable at low revs but when you open it up on a dual carridgeway it pulls like a train. Neither will it embarres you on a trackday. With this spec you could blow stage 1 1275's out of the water
If you want blistering street use and track day performance then you can gas flow, port and polish the head. Fit bigger valves in the head. Combine this with a 'hotter' camshaft such as a Kent 276 or suchlike and a few other bits and peices around the engine and you could well have 70-80brake out of her.
Vizard did a similar spec without lightened flywheels etc which blitzed the metro turbo over the 1.4 mile and that does 0-60 in 8.9 secs. Imagine quicker in a 998!
Threads.
Racer Pete 1 http://www.theminifo...x...=110678&hl=
Racer Pete 2 http://www.theminifo...howtopic=122994
Liiarge http://www.theminifo...showtopic=94825
Stevee http://www.theminifo...howtopic=182587
Phillip G Caldwell http://www.theminifo...howtopic=172059
You will notice that i dont have a thread on here. This is due to my over sensitve approach to security. However you will see enough on here about what im planning to do.
Food for thought
#35
Posted 15 March 2011 - 11:24 PM
Annoying as i have loads of ideas for the engine! Have to think within reason though, as it is my first rebuild. Best not to be too ambitious on my first attempt right?
P.s did you like the picture heavy update?
#36
Posted 15 March 2011 - 11:32 PM
Do it in stages. Im in a very similar situation to you, studying politics and only working part time at the moment.
1. Stage one kit
2. Carb Improvments
3. Head improvments
4. Rocker Improvments
You can do all the above easy without having the engine out which is nice for a daily drive.
5. Engine out time.
6. Camshaft
7. Clutch and Flywheel
8. Crank
9. Gearbox
I could go on but thats a good idea for you
#37
Posted 15 March 2011 - 11:38 PM
#38
Posted 15 March 2011 - 11:49 PM
I would get a decent exhaust for it.
Then do twin carbs
Then a modified 12g295 head
If you need any help just ask me mate,
#39
Posted 16 March 2011 - 08:21 AM
You can source a Mg metro camshaft (people have very goo results with this cam) on ebay for alot less than a new unit, they do turn up on flebay now and again, just keep your eyes peeled
If the cam bearings look ok, dont replace them (I wish I hadnt, its holding my build up now as you need a tool to insert them), this will save money
stick with standard carb (HS4) for now until engine is run in properly then play about with twins, more money saved
instead of having it bored and buying new pistons (£££), might be make more sense to hone the bore and re-ring the original pistons, more saving
I would however part with the money for an ultralight flywheel
#40
Posted 16 March 2011 - 11:56 AM
Phillip, was your car verto or pre verto clutch? Bit confused with flywheel assemblies to fit both :/
#41
Posted 16 March 2011 - 12:36 PM
the engine currently in my mini is verto, the engine iam rebuilding is preverto - I have bought a preverto ultralight flywheel and clutchplate with a pre engaged ring gear on it so I can use my existing starter motor, I also already run my verto engine with a preverto slave cylinder
this is the one I bought http://www.minisport...o_C-AEG620.html
#42
Posted 16 March 2011 - 09:11 PM
OhhhhI have a 12g202 head in the garage somewhere...
#43
Posted 16 March 2011 - 09:54 PM
#44
Posted 16 March 2011 - 10:15 PM
#45
Posted 16 March 2011 - 10:36 PM
