Leaking Oil From Drive Shaft
16 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 10 March 2011 - 06:35 PM
hi guys i have been fitting a new exhaust today and i have noticed its leaking oil from the drive shafts quite bad . is this a really bad thing and what do i do to stop it
thanks lee
its leaking from the end were it joins into the gearbox
hope this helps im sorry if it dont im new to all this stuff so i might now be up to scratch lol
#2 speediestevie
speediestevie
  • 28 posts
Posted 10 March 2011 - 06:51 PM
I had this on my car, minispares had some diff output shaft oil seals that go inbetween the cv joint and the casing. Think they were 80p each you just have to drop the driveshaft from the car by undoing the top balljoint on the swivel hub, then carefully knock out the cv joint from the casing using a piece of slightly bent metal pivoting on the casing nut. After you get it out swap the seal and push it back into the casing and replacing the driveshaft and tightening the balljoint up again. :)
Havent got any pictures but hope this helps a bit
Stephen
#3 minilee94
minilee94
  • 3,523 posts
Posted 10 March 2011 - 06:53 PM
oh right mate yeah that helps thanks
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 March 2011 - 07:07 PM
Get hold of the pot joint (while it's still attached to the gearbox) in your hand, if you can wobble it up and down then it's likely that the bush in the diff cover has worn, so no matter how many times you change the diff seal, it'll still leak.
#5 minilee94
minilee94
  • 3,523 posts
Posted 10 March 2011 - 07:13 PM
oh right okay OMG thats all i would need for that to be broken lol as i havnt got enough problems as it is lol
#6 Stevee
Stevee
  • 0 posts
  • Local Club: #
Posted 10 March 2011 - 07:19 PM
Its a mini ;] if you have not got problems, well you have a problem!
#7 minilee94
minilee94
  • 3,523 posts
Posted 11 March 2011 - 04:22 PM
hi i checked my drive shafts and they dont move up and down but is still leaking so could it be the seal thanks lee
its leaking from behind the drive shaft heres a pic Posted Image
Edited by minilee94, 11 March 2011 - 04:23 PM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 March 2011 - 04:39 PM
That looks like an Auto....
Fortunately they still use the same seal as manuals... p/n ADU5738
#9 minilee94
minilee94
  • 3,523 posts
Posted 11 March 2011 - 06:16 PM
yeah its an auto mate and okay whats the part number u just wrote
Edited by minilee94, 11 March 2011 - 06:16 PM.
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 March 2011 - 07:04 PM
That's the diff seal which you need to replace.
#11 minilee94
minilee94
  • 3,523 posts
Posted 11 March 2011 - 07:50 PM
oh right okay mate and sorry to be dumb lol can you tell me what website thats from please thanks
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 11 March 2011 - 08:51 PM
Part numbers are part numbers, it shouldn't matter who you get it from they should be using BL part numbers.
#13 minilee94
minilee94
  • 3,523 posts
Posted 11 March 2011 - 09:54 PM
oh okay i thought it was a part number from a online shop lol like minispares etc etc
#14 minilee94
minilee94
  • 3,523 posts
Posted 11 March 2011 - 09:57 PM
1 question are they hard to fit ??
#15 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 12 March 2011 - 02:20 AM
add oil and an oil filter as you have should drain the oil when doing this!
