Condenser Problem
Posted 07 March 2011 - 08:34 PM
Posted 07 March 2011 - 08:56 PM
Posted 07 March 2011 - 09:15 PM
it seems a bit unlikely that i get 3 rubbish condensers in a row?
Posted 07 March 2011 - 09:35 PM
However, you stated that the car has a later engine with later wiring. Look at the wires on the coil. Tell us what wires are connected to coil (+).
IF you have a pink and a yellow/white wire on coil (+), that is the wiring configuration for a ballast ignition. Running a 12V coil on wiring for a ballast ignition system will result in a weak spark and an engine that may barely start if it starts at all. The problem may not be with your condensers but with the supply power to the coil.
Do check this and tell us what you find for the coil wiring. It is easy to change to the correct wiring for the coil type once you know what is there to start with.
Posted 07 March 2011 - 09:41 PM
Posted 10 March 2011 - 01:49 PM
then from negative side i have on wire running to condenser in distributor and one running to the rev counter.
do i have the right set up here?
Posted 10 March 2011 - 04:09 PM
Posted 10 March 2011 - 04:50 PM
Posted 10 March 2011 - 05:12 PM
If you want to measure the operating voltage of the coil accurately do the following. Remove the dizzy cap and place a metal coin between the points. Turn the ignition key to the run position and measure between coil (+) and earth. With the coin between the point (effectively making the points look closed) then current is flowing through the ignition system and any resistance caused voltage drop can be measured.
With a coin between the points, if you measure 12V you have a standard ignition setup. If you measure 6-9 volts on coil (+) you have a ballast supply to the coil. If you find 6-9 volts, it indicates that you need a ballast coil. The coil in the link above is for standard ignition systems. Running it on 6-9 volts will result in a very weak spark.
Posted 10 March 2011 - 05:28 PM
http://www.minisport...fo_GSC2111.html
i have a lucas 45D (might be the 59D but i don't know if theres a difference) will this be a reason for this one going soo soon?
Posted 10 March 2011 - 10:04 PM
However, within the past two years there was a thread (on another board I frequent) that investigated the quality of automotive condensers. The author of that thread was collecting as many condensers as possible from different vendors and manufacturers. The conclusion of his investigation was that most automotive condensers are made to be as cheap as possible with little concern for quality and virtually no provisions for the manufacturer to insure that the elements inside the canister are making good electrical contact. The guy who started that thread is an electrical engineer and subsequent to his study, he selected electronics grade capacitors of the right rating and adapted them for use with his A-H Sprite. The capacitor had to be mounted external to the distributor but to the best of my knowledge that's what is still on his car today.
Posted 11 March 2011 - 01:39 AM
Posted 11 March 2011 - 04:18 PM
Posted 12 March 2011 - 02:05 AM
For more information on condensers you may want to take a browse through the threads in the following three links.
http://www.britishca...t/Number/575156
http://www.britishca...t/Number/593638
http://www.britishca...t/Number/635774
Posted 12 March 2011 - 08:21 AM
I had the same issue with capacitors. The Distibutor Doctor will supply high grade capacitors for £6.95 plus VAT. I haven't used them yet as my Mini has been off the road for a couple of years but I'm definately going to try one.
we had a problem with condensors failing after about 20 miles at work, not good on customer cars, we get ours from distributordoctor now, along with rotor arms, and havent had any problems anymore.
Their made cheaply as people dont seem to like paying too much. You get what you pay for.
