Copper Grease
11 replies to this topic
#1 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 07 March 2011 - 06:15 PM
Hey guys I'm starting to out stuff together like hubs n bearings engine bits, should inherent using copper greAse on all bearings and were else should I use it and should i of used it
On the hub bearings. Bassically I have no idea where to use it so a little guidance would be fantastic
YetI
#2 Cooperman
  • 23,276 posts
Posted 07 March 2011 - 06:24 PM
YetI
Copper grease is not a suitable lubricant for ball or roller bearings, nor for greasing grease points.
It's main use is as an anti-seize coating for bolts and nuts, typically damper mounting bolts, sub-frame mounting bolts, etc.
It is not intended for high temperature use or for use on high-speed rotating mechanisms.
#3 iDemonix
iDemonix
  • 962 posts
Posted 07 March 2011 - 06:34 PM
Copper Grease for threads and suck, normal grease for bearings and moving parts.
#4 Cooperman
  • 23,276 posts
Posted 07 March 2011 - 06:38 PM
Not quite:
HMP (High Melting Point) grease for wheel bearings.
Normal grease for swivel pins, radius arms, and other normal grease points.
Copper grease for nuts & bolts and other fixed parts.
#5 Cater_Racer
Cater_Racer
  • 423 posts
  • Local Club: HRCR
Posted 07 March 2011 - 07:54 PM
Not quite:
Thanks Cooperman timely reminder. :w00t:
#6 Cooperman
  • 23,276 posts
Posted 07 March 2011 - 08:16 PM
Not quite:
And I should have added:
Molybdenum Disulphide (black) grease for CV joints and inner drive shaft joints.
#7 MiniLuke
MiniLuke
  • 1,205 posts
Posted 07 March 2011 - 08:26 PM
Is it copper grease they use on the back of brake pads to stop brakes squeeling? sparingly of course.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 07 March 2011 - 08:38 PM
It is :w00t: also if you want to grease very high temperature items like exhaust manifold studs/bolts/nuts etc then you need a nickel based product like Never-seez.
Edited by sonikk4, 07 March 2011 - 08:43 PM.
#9 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 07 March 2011 - 09:36 PM
lovely jubbly guys so i need some high temp stuff for my bearings
YetI
#10 MRA
MRA
  • 7,607 posts
Posted 12 March 2011 - 07:07 PM
I used some extremely expensive ultra high temperature silicon sealer on my own pads to stop them from squealing, works really well, as it also "sticks" the pads to the pistons, which helps retraction from the disc when you are off the brakes.... lower frictional forces :mrcool:
#11 jamesmpi
jamesmpi
  • 1,940 posts
Posted 12 March 2011 - 07:19 PM
Best use for copper grease is on your wheel bolt threads and also on the hub face to stop your brake discs welding themselves to the hub with rust. Also as mentioned above, on the back face of your brake pads
#12 mini13
mini13
  • 3,810 posts
Posted 12 March 2011 - 07:21 PM
Its best used for greasing coppers...
