Running Inner Tubes,
11 replies to this topic
#1 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 March 2011 - 09:59 PM
Hi guys, im going to be running inner tubes on my force spilt exactons, but have been told today that running innertubes on the road is illegal.
just wondered what you guys thought/know.
YetI
#2 rick.spi
rick.spi
  • 1,686 posts
  • Local Club: "WOT NO BRAKES"
Posted 04 March 2011 - 10:02 PM
its fine. and even if it wasnt how would they ever tell.... no worries.
#3 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
I'm no expert. But spoked wheels run inertubes... and cars were built like that.
Maybe there is a certain year from which this rule applies.
Steve
#4 mini_mad69
mini_mad69
    Let future you worry about it
  • 5,417 posts
  • Local Club: urrrr no
Posted 04 March 2011 - 10:08 PM
Inner tubes are quite common, ive seen them used on old wheels that arnt sealing anymore.
#5 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 March 2011 - 10:10 PM
the only reason it came up was because the work landrover got a puncture and we run tubes on it and theAA and the bloke at nationwide tyres
YetI
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 04 March 2011 - 10:11 PM
Running inner tubes inside tubeless tyres is what's illegal, not simply running them. Or at least everyone says it's illegal, I have never found it actually written anywhere myself. Many tyre fitters won't fit them though. Whether legal or not, it is against the tyre manufacturer's specifications (which is why you can have trouble getting them fitted) which can lead to insurance trouble in the event of a claim. Make sure your insurer knows about it, just in case.
#7 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 March 2011 - 10:14 PM
ok so the fact im fitting the tyres etc my self as there spilt rims means i should be fine yay
YetI
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 04 March 2011 - 10:21 PM
It would appear that it is NOT illegal to run inner tubes in a tubeless tyre however it would need to be the correct type of inner tube for the tyre. Due to modern low profile tyres there are very few if any inner tubes that will fit which is probably the reason why you will never see them fitted.
There are numerous vehicles on the road that use tubed tyres but these are designed for it. Trailers etc will have them but again that also depends on the wheels fitted.
At the end of the day the manufacturer of the tire and its intended use will be the deciding factors as to whether you can use an inner tube in a modern style wheel combination. And the availability of a suitable inner tube.
Have a good search on the internet there is lots of info on there regarding inner tubes in car tyres.
#9 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 04 March 2011 - 10:24 PM
YetI
Surely split rim wheels do not need inner tubes, due to the tolerances involved in machining plus suitable sealant then they should hold air pressure no problem??
#10 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 March 2011 - 10:28 PM
carl at force racing says that you need to run innertubes he makes the wheels so im going to trust what he says
#11 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 04 March 2011 - 10:29 PM
Fair enough but i would ask him which ones he recommends.
#12 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 04 March 2011 - 10:31 PM
i shall do
cheers
