Austin 1300 Gt Engine
35 replies to this topic
#16 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 02 March 2011 - 06:32 PM
anyone have any ideas what it all is if not do you no were i could find out
#17 Cooperman
  • 23,213 posts
Posted 02 March 2011 - 07:29 PM
The big-end journals look like 1.75" dia and the rods have the heavy caps, so it looks like a 1300 GT engine. In fact, it's just like my Innocenti 1300 engine with an 11-stud head, but with larger 33.5 mm inlet valves.
#18 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 02 March 2011 - 07:35 PM
any idea what the head is? also do the pistons look usable and finally will the black need honing?
#19 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 02 March 2011 - 11:01 PM
Thanks for that. Any ideas of a good cam and rockers to go with the engine
#20 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 03 March 2011 - 05:06 PM
has anybody got one of theses engines in there mini also what is a good spec for one.
which carbs would be better twin 1 1/4 of a hif44?
Edited by clivemk1mini, 03 March 2011 - 05:07 PM.
#21 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 03 March 2011 - 05:13 PM
Do you need a remote gearbox for your car or are you planning to run a rod change?
Generally they are that easy to change I would install what you have in the car and then rebuild the GT engine at your leisure / budget.
#22 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 03 March 2011 - 05:23 PM
i will put a rod change gearbox on the engine. i was thinking of putting the other engine in until the gt engine is built up, the car is far from ready for the engine as you can see from the picture.
would building the engine be a job i could do myself as the closest ive ever come to building an engine was a head rebuild on my first mini about 12 years ago.
#23 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 03 March 2011 - 09:41 PM
If it was me I would clean and paint the engine I had (if the vital signs looked good) as an engine rebuild is one less job to complete to get it on the road !! :))
Invest in the Carver DVD of how to build a 1380 as it is a good step by step guide what ever spec you deciede.
#24 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 07 March 2011 - 12:27 AM
Thanks for the advice sounds like a good idea will probably take the head of the other engine just to see what the bores are like because it's been sat in the garage for 3yrs It still turned over by hand but might be worth a look
#25 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 16 April 2013 - 06:44 AM
I dont think any cooper s s had sold backs!
#26 ace01
ace01
  • 457 posts
Posted 16 April 2013 - 09:17 AM
Correct. :shades:
#27 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 16 April 2013 - 07:25 PM
Most Mk3 S has no tappet chests
That is wrong, the Mk 3 S had the AEG 312/AEG634 thick flange block
1300GT has ... S rods
That is also wrong, the GT crank has the larger (1.75") big end journals.
#28 pdaykin
pdaykin
  • 587 posts
Posted 16 April 2013 - 08:19 PM
New cooper S engines with removeable tappet chest covers - not gold seal/silver seal - were still available after the Cooper S ceased production. I have one, as have others on other forums.
I cannot see any reason why a mk3 Cooper S would have left the factory with a solid block engine.
I don't think the base S engine shared anything of significance with the 1275gt or 1300gt
#29 JVA10L
JVA10L
  • 181 posts
Posted 16 April 2013 - 08:47 PM
I know someone who had a J plate Mk3 'S' and it had a thick flange solid block and an EN16T crank with 'S' size journals and 'S' rods.
Look up the Moss 'classic mini' catalogue tech advice section page 9, all the part numbers are there.
Also, this engine number 12H/---/ is specified as '1275 Austin ADO16 & Allegro'.
Edited by JVA10L, 16 April 2013 - 08:52 PM.
#30 62S
62S
  • 1,243 posts
Posted 17 April 2013 - 07:03 AM
12H/495F/ is a 1300 GT engine not an Allegro engine.
Why would BL mess about putting an EN16T Mk 3 1275S crank in a 1300 block when they were still building S engines in S blocks? The Mk 3 S crank and 1300 GT crank were made from the same forging.
