Fixing Mud Flaps, Screws Or Clamps?
4 replies to this topic
#1 wardyxxx
wardyxxx
  • 1,327 posts
  • Local Club: Leicester Mini Club
Posted 21 February 2011 - 05:42 PM
Evening all, i I'm gonna buy Lulu some mud flaps, which is the best way to secure them?
She's a sportspack so srewing into the arch is a possibility, or I was going to buy these, but insert an extra bolt to act as a locking bolt if you know what I mean.
http://cgi.ebay.co.u...atchlink:top:en
Ta muchly,
Tom.
#2 charie t
charie t
  • 3,153 posts
Posted 21 February 2011 - 05:54 PM
Normally they're riveted on, those clamps are a bit more forgiving should you catter them on a kerb or elsewhere.
Rivnuts maybe an alternative if you wanted
#3 wardyxxx
wardyxxx
  • 1,327 posts
Posted 21 February 2011 - 10:00 PM
That's what I thought, might be at a greater risk of them falling off, but are less likely to rip the arches off.
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 21 February 2011 - 10:29 PM
I really would think twice before buying the mud flaps in the first place if I were you, I've had them fitted to a number of cars over the years and they act as terrible dirt, moisture & rust traps, which really is the last thing you need on a classic mini! If you are still set on buying them though then rivet them in place, being sure to treat and paint any drilled/exposed bare metal properly before fitting. Also make sure that you get a pressure washer in and around the mounting points regularly, to wash away any accumulation of dirt that will atrract mositure and cause corrosion.
Edited by AVV IT, 21 February 2011 - 10:29 PM.
#5 wardyxxx
wardyxxx
  • 1,327 posts
Posted 21 February 2011 - 10:38 PM
Yeah, that's why I've held off fitting them for a while. She's only really used in the summer, when I'm back from uni. Its just to stop stones, I live up a bad farm drive.
The clamps only hold onto the fiberglass arches. So no metal would be exposed, and they'd rarely get wet. Aesthetics really.
