Facet Pumps
Posted 21 February 2011 - 11:44 AM
Posted 21 February 2011 - 01:17 PM
The fuel pump only needs to move fuel to the float bowl, gravity and engine vacuum take over from there. The pump does not force fuel into the main jet of the carb.
What you need to pay attention to with any aftermarket pump is the delivery pressure. SUs do NOT like high input pressure from the pump. Ideally, the pump pressure would be between 2-3 PSI. You can go a little bit above that, but once you exceed 4 PSI you need to consider adding an inline fuel pressure regulator (after the pump and before the carbs). Do NOT use the cylindrical, chrome plated, cheap regulators.
(Do not use this type: http://ecx.images-am...L500_AA300_.jpg )
Only use a quality regulator that can hold its setpoint.
The Facet "red top" pumps have a built in filter that can be replaced and they are quieter than the "cube" or "brick" pumps that cost less. However, apart from the noise and price, you are not likely to note any performance differences between the two.
Posted 22 February 2011 - 12:33 PM
hi doug l,thanks for your info,didnt think i was getting any feed back as i noticed a similar thread after posting mine only he is running turbo,regards john.Any of the Facet pumps will deliver enough fuel for your engine. The standard mechanical pump would be fine also.
Posted 22 February 2011 - 03:51 PM
anf fitted it to rear subframe......
Posted 22 February 2011 - 06:24 PM
Hi..I fitted a facet to my mini 1380...............
That's a nice neat installation.
Posted 22 February 2011 - 09:16 PM
Posted 22 February 2011 - 10:31 PM
yes they are noisy even rubber bushed to subframe......... as for the filter its a pre pump gless filter wich you can open and clean.......... http://minispares.co...ty=pb&pid=37901hi,will try and copy yours can you tell me what filter you use and is it as noisy as some say,regards john.
Posted 25 February 2011 - 12:13 PM
hi all,thanks for your imput,regards johnyes they are noisy even rubber bushed to subframe......... as for the filter its a pre pump gless filter wich you can open and clean.......... http://minispares.co...ty=pb&pid=37901hi,will try and copy yours can you tell me what filter you use and is it as noisy as some say,regards john.
Posted 26 February 2011 - 11:21 AM
hi all,just looking at pics again to make bracket andnoticed the wireing looks prety heavy what type and how to wire in as old pump was mechanical,regards john.hi all,thanks for your imput,regards johnyes they are noisy even rubber bushed to subframe......... as for the filter its a pre pump gless filter wich you can open and clean.......... http://minispares.co...ty=pb&pid=37901hi,will try and copy yours can you tell me what filter you use and is it as noisy as some say,regards john.
Posted 26 February 2011 - 05:53 PM
Posted 27 February 2011 - 01:30 AM
Posted 27 February 2011 - 06:11 PM
hi all,1972 so negative earth,regards john.Mk1leg, regarding color codes... is your car positive earth?
