A ????what you reackon?
Project Started
#76
Posted 05 September 2011 - 08:31 PM
#77
Posted 05 September 2011 - 08:54 PM
#78
Posted 05 September 2011 - 08:55 PM
#79
Posted 05 September 2011 - 09:48 PM
#80
Posted 05 September 2011 - 09:50 PM
can you send pictures from both scuttle end joints (wing to scuttle) as it is at the moment?
Edited by minimuk, 05 September 2011 - 09:57 PM.
#81
Posted 06 September 2011 - 07:16 PM
now for the pics of the front of the front end , wings to the front panel, the gaps will be ok when its all welded up as i will closes them up a bit more dont forget this is a ruff fit at the mo just to see if the front end is all strat .
the weekend iam takeing the car over to my work to get sum filler work done to the bulkhead and get all the new panels in primer before welding them on . order the new door steps and lamp repaire panels for the back today so shud be here thurday all being well , so that left to do and door skins left to change and sum bits and bobs to weld up .
#82
Posted 06 September 2011 - 08:46 PM
Also can you get a few piccies from the scuttle joint please, both sides?
once the scuttle joint is correct and the "gutter gap" is less wide (6mm-10mm), and A-panels fitting correct, you can attack the front panel and wing joints, they are a pain and every one will tell you the same.This needs to be done first always start at the beginning not in the middle
Overall in the pictures the front joints do not look that bad, you can pull the offside and nearside joint easy toghether starting from the light-innerwing joint 1" at the time clamp it then tack it,...do both sides then weld the front panel in it.s final position onto the inner wings,...BUt dont weld till the joint is tight!!
I have seen one guy connecting the front panel with the wings first and then took it to the car, all god however the a-panels where out and wings did not fit scuttle ends, ended up sarting again, don't forget every mini is different.
#83
Posted 06 September 2011 - 09:10 PM
the scuttle panel gap are great and the a/panels to the doors and wings are all good line up fine so i welded the a/panel on , but what i am thinking about now is to cut down the the lip on the inside of the wing both sides ( just a little ) to help closes the gap up to the bonnet and then roll the wings in to give me the gap size i needs it a mix of genuine and non genuine panels, mixing or just non genuine panels are never accurate and never a perfect fit, thats where you come in and test your patience.
#84
Posted 06 September 2011 - 11:36 PM
#85
Posted 07 September 2011 - 07:02 PM
#86
Posted 07 September 2011 - 08:35 PM
#87
Posted 07 September 2011 - 08:58 PM
well all is food for thought, I do think sometimes it helps to be away from the mini,....but not too long!!!!
lmaf tell me about it had to much time away from in the past 7 mouth but still the money comes 1st
#88
Posted 11 September 2011 - 06:19 PM
FILLED AND PRIMED
FILLED AND PRIMED
#89
Posted 11 September 2011 - 07:36 PM
#90
Posted 11 September 2011 - 07:49 PM
neat work there, you have done that before for sure, amazing transformation with a coat of primer.Glad you did that as damp weather is coming this way, keep the rust away!!
lmaf well you got kida yes i have done alittle paint and filler work before ( between me and you only for 17 years lol ) but don't tell no one
