Does It Need Skimming?
Posted 18 February 2011 - 07:48 PM
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
austin mini 1000 city e
1983
My head gasket went the other day and im hopefully getitng it done tomorrow, but does it need skimming? or would i get away with not doing that?
if its a must how much does it usually cost?
Cheers Scott
Posted 18 February 2011 - 07:55 PM
~~~~~Please delete this text before posting the topic~~~~~~
1983
Cheers Scott
If the gasket went and trhe engine did not get too hot and/or run completely oiut of water then you should be OK.
Just get some abrasive material, aluminium oxide paper is goot with about 240 grit, and place a strip of it on a piece of flat wood about 3" x 6". Clean back the head with this, then wash the head thoroughly in paraffin and re-fit with a good quality gasket. Clean back the face of the block before re-assembly making sure all the old bits of gasket are off and the face is clean and grease-free.
Posted 18 February 2011 - 07:59 PM
its still pretty much full with water so fingers crossed when i take the head off tomorrow it doesn't need skimming as thats just another pain, and longer wait till i can drive her again =D
Posted 18 February 2011 - 08:04 PM
okay thanks cooperman
I'm 99% sure it will be fine without a skim. A Mini head needs to be seriously overheated before it warps. If it was an alloy head that would be different, but those old cast-iron ones are very tolerant. Just make sure you torque it up correctly when re-fitting. Also buy a top quality gasket, not one of those cheap grey-coloured rubbish ones some of the general motor factors sell. Get one from Mini Spares or Mini Sport or one of the other major Mini parts suppliers.
It'll be back on the road in no time.
Posted 18 February 2011 - 08:13 PM
No, not usually. People will tell you that you must skim the head if the gasket fails, but most people have limited experience with a cast iron engine. The head and block are very rugged, iron is pretty hard to warp with a little heat. Not that you even know that the gasket failed due to heating. Gaskets do just fail because they are old. Every time you skim it you raise the compression ratio and change the valve geometry so anyone who tells you to skim it just to be on the safe side has not considered the full implications. You can only tell if it needs to be skimmed by measuring it, and should do the same to the block. Don't skim it as a matter of course though.
"SNAP"
Posted 18 February 2011 - 08:45 PM
Posted 18 February 2011 - 08:48 PM
No a ruler is not a straight edge
Posted 18 February 2011 - 08:51 PM
"SNAP"
Thanks guys that a huge relief so i can just hopefully change the gasket tomorrow, got it off mini sport llus the timing chain
Posted 18 February 2011 - 08:53 PM
Posted 18 February 2011 - 09:32 PM
Or will my standard toolbox do the job?
Posted 18 February 2011 - 09:38 PM
Posted 18 February 2011 - 10:12 PM
I managed for years and years without a torque wrench - but I have had one for many years now, and ideally it should be used.
Didn't this come up in a thread recently?
Get a torque wrench, it's a worthwhile investment.
If you've got the time, get a valve spring compressor and valve lapping kit, and relap the valves. Not strictly necessary, but worth doing if you have the time
Posted 19 February 2011 - 04:12 AM
Posted 19 February 2011 - 07:44 AM
