Recommend Me A Carb Balancing Tool
Posted 15 February 2011 - 07:42 PM
Posted 15 February 2011 - 09:10 PM
Apart from the obvious 2 foot piece of garden hose, there are 2 main contenders. This typeI need to balance my twin HS4's accurately - can anyone recommend be an affordable flow meter type?
http://cgi.ebay.co.u...=item43a2e1a4e5
And this type
http://cgi.ebay.com/...sQ5fAccessories
I have used the first type which is very good but a little more expensive at around £35. To see the second type being used look here, appears to work perfectly well.
http://www.youtube.c...751E1396854887A
These often come up on Ebay UK, search for carb sync, Uni-syn, carb synchroniser, carburettor balancer.
Edited by tommy13, 15 February 2011 - 09:20 PM.
Posted 15 February 2011 - 09:39 PM
Posted 15 February 2011 - 09:52 PM
Unless you are deaf of course!
Posted 15 February 2011 - 10:07 PM
Posted 16 February 2011 - 12:49 AM
See this link below. Scroll about 1/2 way down the page to the picture UNDER the picture of the Unisyn tool.
http://www.sw-em.com/su_carbs.htm
Basically you put a dowel with a bent wire in each carb's dashpot oil reservoir. With the engine stopped and the carb pistons resting on the bridge you point the wire tips directly at each other (but not touching). You start the engine and adjust the idle screws on each carb to the desired speed while maintaining the wire positions so they still point at each other. Then you tighten the carb linkage as normal so the carbs will operate in unison.
Posted 16 February 2011 - 09:53 AM
Posted 16 February 2011 - 01:02 PM
Posted 16 February 2011 - 01:48 PM
So if you want one, I'd suggest the Synchrometer one. If you got good ears, then go for the pipe thing.
Posted 16 February 2011 - 04:52 PM
Think I'm edging towards the Weber one as mentioned - cheers.
It says it goes down to 40mm carbs, HS4's are smaller - is this still ok?
Edited by AlexP, 16 February 2011 - 04:52 PM.
Posted 16 February 2011 - 05:32 PM
but with no way of validating what I hear I have no idea!
The same noise (suck) through both inlets....
Posted 16 February 2011 - 06:57 PM
Posted 16 February 2011 - 07:27 PM
Posted 16 February 2011 - 07:29 PM
how exactly do you tune a carb with a bit of pipe
You don't, you balance them. Listen to the air rushing past, match it on the two carbs, then keep working down to a good idle speed. Good idea to do mix first as changing mix will change idle speed revs or current ones anyway.
