As above.
Ive taken off the flywheel cover, which was a little fiddly, but i want to take the housing out. In the Haynes it says remove the engine, but im looking at it thinking do i really have to?
Can You Remove The Flywheel Housing Without Removing The Engine?
Danny Newton
, Feb 14 2011 04:56 PM
5 replies to this topic
Posted 14 February 2011 - 04:56 PM
Posted 14 February 2011 - 05:08 PM
Nope its an engine out job...You can undo all the nuts and bolts while its sill in the car but you just cant get it over the crank tail because the subframe gets in the way. You could just jack up one side of the engine to gain the space but you will have to undo all the bits (Manifolds, cooling) so you might as well just wheek it out.. We han an engine out and on the floor in 45 mins yesterday... But thats a record for us... Give your self 1.5hrs..
Posted 14 February 2011 - 05:30 PM
You can, but to be honest it just easier to take the whole lot out...
If you do want to try it 'in car', remove the top radiator bracket, this allows you to jack up the flywheel side of the engine at such an angle and affords the necessary clearance to remove the transfer case over the crank tail.
Posted 14 February 2011 - 05:32 PM
Cheers mucker
Posted 14 February 2011 - 05:56 PM
Ive done it a few times to change drop gear ratios, its tricky but possible. I remove the radiator
Posted 14 February 2011 - 08:14 PM
did it a few weeks ago to check the thrust bearing and clutch! don't bother! 3 hours and skinned knuckles oh and a scratch on the inner wing! Take the engine out!!
