The Best Gauges To Put In?
8 replies to this topic
#1 sam27
sam27
  • 235 posts
Posted 12 February 2011 - 11:26 AM
hi im not sure if this is the appropriate section to put this in but if it isn't im sorry :/ but what i would like to no is, im wanting some small gauges (oil pressure ect) in a gauge bracket attached to the top dash rail because i have a open dash but im not sure what would be the best sort of gauges to put in ... i defiantly want the time in there but what else i don't no i was thinking oil pressure, battery and maybe fuel ?? and if so weres the best place to get these gauges? thanks sam
#2 crazycoleman118
crazycoleman118
  • 836 posts
Posted 12 February 2011 - 11:28 AM
anywhere and everywhere sells gauges, most people go for volts, oil pressure vaccuum maybe, if you want a clock you might be better off going for the classic look mechanical gauges as ive not seen a modern clock type one, minspares/sport sell some, and so do ebay
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 February 2011 - 11:36 AM
What gauges do you have already? Do you really need two fuel gauges? If you don't have water temperature gauge then get one, same goes for oil pressure, and a time clock and a voltage gauge are probably the most useful.
#4 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 12 February 2011 - 11:43 AM
As above, oil pressure is the most important one, followed closely by water temperature. After that then a voltmeter is very handy to have in an older car like a mini, ammeters are good but not recommended with alternators, as if they fail they can also destroy your alternator. (Saying that I do have an alternator wired in to my Landy!)
#5 sam27
sam27
  • 235 posts
Posted 12 February 2011 - 12:07 PM
at the moment i have the 3 clocks like the standard to but with rev counter attached
also were could i get a bracket to put them in??
Edited by sam27, 12 February 2011 - 12:17 PM.
#6 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 12 February 2011 - 01:26 PM
I've got a time clock, and voltmeter in mine. Then still have the standard 2 dials with fuel, water temp, and speed. - All I need really!
#7 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 12 February 2011 - 01:55 PM
1. Oil pressure gauge - (very reassuring & could save your engine from disaster!),
2. Voltmeter - (very useful & can answer an awful lot of questions if your car wont or, is struggling to start!)
3. Time Clock - (saves you trying to catch a glimpse of your wrist whilst driving, especialy in the dark!)
#8 crazycoleman118
crazycoleman118
  • 836 posts
Posted 12 February 2011 - 02:26 PM
have you looked on ebay, minispares/sport yet? theres loads everywhere just look
#9 mingy
mingy
  • 930 posts
Posted 12 February 2011 - 09:41 PM
I would suggest you put a temperature / oil pressure / volt meter gauge setup in the car as these are the most important things you need to keep an eye on. If you have,nt got a centre binnacle then obviously a fuel gauge is more important than a volt meter. Try the "Gauge Shop", i got reconditioned full face smiths gauges from them and they are great.
