Ford Ka Dash Conversion
41 replies to this topic
#1 minibarnerz
minibarnerz
  • 479 posts
  • Local Club: torbay mc, somerset rusteez
Posted 11 February 2011 - 06:19 PM
well, got my dash today and started to try and fit it,
thought i would show my progress as i go, seems to be a bit different and getting a bit more popular.
sorry about the poor quaality of some pics - iphone cameras are *poo*
here is the dash.
as you can see, the dash standard is too wide!
and sits WAY to far forward!
so started by chopping some off the top of the dash, i decided to go with thw whole " easier to take more off, than put it back on" scenario, so was cautious at 1st. thaught maybe i could try to use the KA's de-mister vents, so chopped it just before then...
this then gave me a better idea of where to chop it at the ends.
first lined up the dash to be approx where i willl want it!
then marked where i want it cut off!
then cut!! :/
sits in better now, still sits too far forward tho! so more precise fitting tomorrow, ran out of daylight today!! :thumbsup:
#2 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 11 February 2011 - 07:55 PM
it will catch the heater at the middle of the tear drop bit on the inside of the drivers footwell mate, and the bottom dash rail will catch in places like the pocket on the left hand side. are you going to mod the gear lever?
#3 Ju Boy!
Ju Boy!
  • 325 posts
  • Local Club: The Beaminster Mini Massive!
Posted 11 February 2011 - 08:03 PM
love this! i have a KA dash sat in my shed for almost 3 years now! :thumbsup: and i still havent tryed fitting it yet! but because of this i might jet give it a go! top work keep it up :D
#4 minibarnerz
minibarnerz
  • 479 posts
Posted 11 February 2011 - 09:24 PM
I haven't got a heater in me car as it was a hill-climber b4 I got it!! Think wen it comes around to putting one back in i will investigate n work my fabrication skills at that time!
I know it needs more trimming, I will get back to it tomorrow with the rest ofthe fitting guide!! (this is my 1st attempt so your all gonna see what it's like rather than some1 who doneit loads of times makin it look simple!!) haha
#5 minibarnerz
minibarnerz
  • 479 posts
Posted 12 February 2011 - 01:23 PM
how it was sitting yesterday evening when i finished with it
obviously how you want it to sit is going to be completely dependent on personal choice, will be different for everyone, depending on your hight, seat type and personal preferance!
but i felt this was still too far forward! line of sight to the speedos was completely off for me and my knees would b hitting the cowling under the steering wheel!
so again marked off on the top of the dash, still on side of caution where i would cut it....
and cut it... decided to show both pieces i cut off, so you can see the total amount!
this meant that the vents for the de-mister are now covered up, so will have to do something about that later!
also now the dash is sat further forward, the plastic on the underside of the dash needs to be removed, it suppied air for the vents etc and also this compartment (im guessing airbag for up-market models?!?)
here it is all off
this is a pic of the back of the dash with all the bits removed (alot of it was just glued on)
now i re-fitted the dash, it sits alot better possision but now the glove department hits on the lower dash rail, causing the top corner to lift up.
also this small compartment the other side of the dash also hits so got cut out.
so again, marked where it needed to be cut, and removed more plastic!
it now sits well, and find the dash pod is quite well lined up!
so i temporaraly held it in place just with a rivet in each top corner...
at this point decided to leave it for today... but when i came inside wondered if the mini clocks would fit inside the Ka dash pod...
looks like i might be able to do something with this....
this is how its looking so far:
but for now, its going to have to wait, apparently there is a rugby match about to start!! :P come on England!! :(
#6 minibarnerz
minibarnerz
  • 479 posts
Posted 12 February 2011 - 01:33 PM
clearance of the steering wheel on the dash pod can also be an issue, mine is dished but still not too much gap!
#7 walkersky
walkersky
  • 34 posts
Posted 13 February 2011 - 02:22 PM
good work, keep it up
#8 blue blood
blue blood
  • 806 posts
Posted 13 February 2011 - 02:52 PM
Should get a stainless longer steering wheel drop bracket i know tomkidd has one more left. If your quick you could buy it it would lower the steering wheel and give a larger gap between dash and wheel :).
I've got one on the last page of my current build if you want to have a look:-
http://www.theminifo...howtopic=174924
Regards Blue
#9 minibarnerz
minibarnerz
  • 479 posts
Posted 13 February 2011 - 03:43 PM
it already is dropped... its just that tight!! :)
decided to see about fitting my dials today. started with the Rev counter.
saw that H4wx1e had fitted his in the air vent closest to his dash, but i found that this would be obscured by my steering wheel so gonna try fitting it in the other one.
i had to cut back some of the casing of the dial due to curve of the dash, then with some very rough fibreglassing held it in place. gonna try it there n see what its like, might end up moving it!
if its ok will attatch it better! :P
#10 h4wx1e
h4wx1e
  • 553 posts
Posted 13 February 2011 - 04:33 PM
looking good mate :)
#11 superman
superman
  • 736 posts
  • Local Club: Dorset Mini Club
Posted 14 February 2011 - 10:04 AM
Should get a stainless longer steering wheel drop bracket i know tomkidd has one more left. If your quick you could buy it it would lower the steering wheel and give a larger gap between dash and wheel :thumbsup:.
Regards Blue
I cut around the curved section which houses the dials and switches then sunk it back into the rest of the dash about 3 inch to give more clearance for the the steering wheel and gear lever as i thought it was a bit close,
the dashboard took over 40hrs work of cutting, plastic welding and poprivets after all that work i took it out and lobbed it the back of the shed, turns out i didn't like the look of it in the shortie
#12 Dan16v
Dan16v
  • 370 posts
Posted 14 February 2011 - 07:13 PM
It looks like you have cut in exactly the same place as mine, apart from the right hand vent, which I managed to keep on there (bit tight against the door though)
I found a bit of drain pipe cut in half made a good cover for the dash rail on the passenger side, I could then keep the small glove box thing in there.
Edited by panelbeaterpeter, 24 April 2011 - 03:19 PM.
No need to quote half a page of photo's.
#13 mini-myles
mini-myles
  • 35 posts
Posted 21 February 2011 - 06:39 PM
This is starting to look good. Keep us updated. Might use your idea in my project :-
#14 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 25 February 2011 - 10:20 PM
Been waiting for one of these threads for ages!
Definately something I'm going to do with mine when it goes off the road for it's full re-build. :lol:
#15 Dan6061
Dan6061
  • 761 posts
  • Local Club: -
Posted 25 March 2011 - 11:19 AM
Any progress with this?
