Brake Master Cylinder Problem
Posted 09 February 2011 - 11:19 PM
I have a 1987 Mini Mayfair. I have the type 3 brake master cylinder with the yellow tag.
My problem is when trying to bleed my brakes I cannot bleed the back ones. The problem lies at the master cylinder...no fluid comes out of the lower hole of the master cylinder when i push the brake pedal.
I rad on this forum and found the suggestion to check at each junction whether there is any fluid but its not even coming out the master cylinder.
The front brakes have been bled so there is pressure in the top hole if that makes any difference.
I have also had the master cylinder off whilst I was doing an engine change and cleaning up the engine bay.
Please any suggestions.....Is my Master Cylinder knackered?
Matt.x
Posted 10 February 2011 - 02:46 AM
Because the lower bore is bigger it creates less pressure than the upper, if you hook it up to the pressure regulator wrong it will cut off the flow from the lower outlet prematurely. Make sure the lower outlet is supplying the rear circuit, and bleed it first.
Posted 10 February 2011 - 01:13 PM
The top is supplying the front brakes and the bottom is supplying the rear brakes.
I cant bleed the back brakes at all because the master cylinder doesnt push anything out.
Posted 10 February 2011 - 10:37 PM
I need to no whether its the master cylinder before I buy a new one or whether there is anything else I can do...
Thankyou.
Posted 10 February 2011 - 11:26 PM
Then disconnect the pipe for the outlet for the rear brakes and press really hard on the brakes, see if you can clear the blockage.
If not, drain the fluid out and run compressed air through the outlet for the rear brakes gently and try the above procedure.
If that still doesnt work, you'll have to strip the master cylinder.
Im not trying to say you're stupid, but make sure you are refurring to the master cylinder and not the compensator mounted on the bulkhead.
Keep us posted
Lee
Edited by lawnmowercrap, 10 February 2011 - 11:27 PM.
Posted 11 February 2011 - 01:51 PM
I definately give that a go either tonight or tomorrow...
And its definately the master cylinder.
Cheers.
Matt
Posted 14 February 2011 - 02:04 PM
When I pushed the brake pedal down hard it just spat a small bit of fluid out and did the same each time..
I used a compressor and its not blocked.
So do I need to buy a repair kit or something?
Posted 14 February 2011 - 03:06 PM
Posted 15 February 2011 - 01:01 PM
Just bought a repair kit off mini spares.
Posted 21 February 2011 - 02:23 PM
But I shall end on a high note. I took my Master cylinder a part and used this repair kit clicky
I have have never done this before and it was reasonably easy to do.
I fitted it back in the car and when I bled the brakes it worked fine, so there was obviously something wrong with the master cylinder.
So I'm happy now.
Edited by Mini_Matt, 21 February 2011 - 02:24 PM.
