Total Rebuild Of '71 Evy
563 replies to this topic
#106 minimuk
minimuk
  • 1,947 posts
Posted 07 November 2011 - 04:14 PM
my text got lost above,
so after the bracing bit, I checked the roof a bit, thought I needed to replace that one, but with a bit sanding and kurust it is not that bad, except the front corners and rear gutter. I have a donor roof so I will use that one for the areas that need replacing, looking on the inside the roof is in very good nick for her age.
I might put in a few hours tmr.
#107 minimuk
minimuk
  • 1,947 posts
Posted 08 November 2011 - 06:05 PM
managed a bit time on her this afternoon, delicate surgery has started, nearside front roof corner,
first how is was to start with,
Attached File  DSC02095a.jpg   59.97K   14 downloads
cleaned the area with wire whool brush on angle grinder, nice job using that.
Attached File  DSC02121a.jpg   57.58K   19 downloads
this is going to be a delicate job, first I will take out the window panel corner,
starting with drilling out the spotwelds
cut allong marked bit and peel back old panel piece, leaving the gutter in it position
Attached File  DSC02123a.jpg   64.21K   20 downloads
cutting out rot and replace with new metal
Attached File  DSC02125a.jpg   56.46K   12 downloads
before cutting out donor piece, wire brush inside the boxing as there was only surface rust in that corner, and coated it with kurust
Attached File  DSC02127a.jpg   51.9K   20 downloads
Tomorrow I will cut out the roof bit and get that area tydied-up as before, and try and tack in the window panel donor piece onto the inside of the gutter, as that will be perfect to get to with the corner cut out.
Edited by minimuk, 08 November 2011 - 06:07 PM.
#108 minimuk
minimuk
  • 1,947 posts
Posted 10 November 2011 - 05:12 PM
contineued with the nearside corner,
cut out the bad piece,
Attached File  DSC02129a.jpg   60.37K   16 downloads
grind and sand the gutter
and Kurust the lot
Attached File  DSC02131a.jpg   64.81K   20 downloads
need to make template, and preperare donor front panel.After that the roof corner cutout of the roof.next few days,.....
#109 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 11 November 2011 - 09:52 PM
lookin forward to how this repaire cums out mate as thats alot of shaps just on the the roof :blink:
#110 minimuk
minimuk
  • 1,947 posts
Posted 11 November 2011 - 11:42 PM
delicate surgery needed here, patience with the patient, time will tell, got to have a good plan..........2 more corners after this one!! will use flattened copper pipe to absorb heat when welding to prevent any kinda warping, I noticed today that there is a 5" piece of roof lip to the gutter end needs replacing too,.....more planning. Just love this challenge,...just like playing chess, got to know your next move and 6 moves ahead,.....back on that on Monday.
#111 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 17 November 2011 - 10:23 PM
well hows the roof goin, moved yet ? forgive me but willit be better to change the hole roof in one go or not ? but far play to ya fella your doing sum thing i wood not do
( bang it full of filler i will make you a corner lmfaf )
Edited by STREET TWEAKS, 17 November 2011 - 10:24 PM.
#112 minimuk
minimuk
  • 1,947 posts
Posted 17 November 2011 - 10:30 PM
had to leave the roof for a few days, massive absess,......I did prime all the kurusted areas I started, back on it on Monday, need clear head, not stuffed full with tabbies,
I do have a whole roof, but......is the new version one with different gutter,and I do want to keep the origional one, more work to cut the old gutter and put onto new roof, once I get going those holes will be fixed before your filler could dry lol(maybe not).
#113 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 17 November 2011 - 10:39 PM
lol did you see my heat lamps in the pics , my filler drys fast i don't mess about ha ha
#114 minimuk
minimuk
  • 1,947 posts
Posted 22 November 2011 - 06:18 PM
starting on the corner today, noticed 2 little holes in the guttering near by,...this needed sorting first.
2 little holes in gutter
Attached File  DSC02132.jpg   71.86K   15 downloads
cut out rot
Attached File  DSC02136.jpg   60.41K   10 downloads
kurust and zinc primed the inside and made template
Attached File  DSC02137.jpg   55.74K   11 downloads
cut out template shape it and drilled spotweld holes
zinck primed the inner side of repair piece and tacked it in position
Attached File  DSC02142.jpg   61.36K   18 downloads
welded and sanded flat
Attached File  DSC02146.jpg   60.25K   16 downloads
zinc primed the lot again
Attached File  DSC02147.jpg   52.46K   19 downloads
noticed a bit of welding blob on the left, needs sanding again tomorrow ,then seam seal, and prime again,
job done,...for now
Happy surgery days...... :highfive:
Edited by minimuk, 22 November 2011 - 06:19 PM.
#115 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 22 November 2011 - 09:05 PM
Nice work there, roof stuff is hugely tricky, too much heat and its game over!!
#116 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 22 November 2011 - 09:18 PM
Hello minimuk - I'm with Shifty on this one. Gutter repairs are incredibly difficult. I hated doing mine. Super job.
All the best
Hugh
#117 minimuk
minimuk
  • 1,947 posts
Posted 22 November 2011 - 10:02 PM
Thanks Shifty, needless to say I did not enjoy the start of it, knowing this kinda surgery is rather tricky
All the best
Hugh
Cheers Hugh, yes it is/was difficult, that little patch took me over 2 hours, but worth while, the corner will be more complex,..so we will see
#118 grahama
grahama
  • 2,442 posts
Posted 23 November 2011 - 11:11 AM
Have to agree, nice work on such a tight area. Glad mine is ok as don't think it would come out as nice !!
Graham
#119 minimuk
minimuk
  • 1,947 posts
Posted 23 November 2011 - 03:38 PM
Graham
Cheers Graham,, I am sure over the time you have enough skills developed to do this kinda work to,....but agree it is not easy to work in such a tight area,......reading the metal and the way a mini is put toghether is a puzzle on it's own, everytime I start on something I haven't done before on a mini, it is time consuming and challenging. Planning is most of the work though,.....
#120 minimuk
minimuk
  • 1,947 posts
Posted 24 November 2011 - 04:25 PM
quick 10 minutes for template,
Attached File  DSC02151.jpg   48.2K   14 downloadsAttached File  DSC02153.jpg   48.08K   16 downloads
cut out metal tomorrow, and shape it
