Total Rebuild Of '71 Evy
563 replies to this topic
#61 tedmcedd
tedmcedd
  • 2,751 posts
Posted 30 April 2011 - 06:56 PM
thats a long list! almost as long as the one i have for my mk2!
the old ones are worth it though :)
i look forward to more updates!
Ed
#62 minimuk
minimuk
  • 1,947 posts
Posted 30 April 2011 - 08:09 PM
you right there Ed they are worth it,... no matter what. It will nearly be a new shell but has something of you init!!
Will start soon, first the other one needs to be finished.
till then
#63 minimuk
minimuk
  • 1,947 posts
Posted 27 July 2011 - 04:26 PM
now Muk is on the road, it is time to play with Evy,....... yes it has been a while,.. I have not got a game plan as yet however, a lot needs doing, the front end is strong again after a bit of doing in Feb and March, I have got a second hand rear panel and that is the first point I want to repair, if that one is in the floors will be next and quarter panels and and and and .......
here are a few piccies from today
rear panel...wha is left if it
Attached File  DSC01541a.jpg   20.73K   17 downloads
cleaning up and tidying of the donor panel, drilling out spotwelds, sanding cutting excess quarter panel of etc, not a nice job, but will be better in the end.
Attached File  DSC01977a.jpg   72.48K   11 downloads
#64 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 27 July 2011 - 07:25 PM
Great work, not messing around there.
#65 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 28 July 2011 - 07:41 PM
Yes agreed. Looking forward to seeing how this progresses.
Hugh
#66 minimuk
minimuk
  • 1,947 posts
Posted 28 July 2011 - 08:13 PM
Hugh
I thought you might,..... this wont be an easy one I can tell you that... the front is strong for now but the rear,......bracing....... lot of planning and logic constructive attack!!!just like a game of chess.
#67 minimuk
minimuk
  • 1,947 posts
Posted 01 August 2011 - 08:36 PM
After a sweltering sticky weekend working, I got back to the rear panel today, removed all the excess quarter trim, and roof strips and all sorts of extra bits.
I wanted to clean it from all the filler and sealants and found that it had a O/Sbottom repair done in the past, a bit of a shady job(buckets of filler), N/S not much better.
Then again it is a donor panel so not moaning about it, cleared all the muck of first and then got a tin of nitro-morse on it, cleared and cleaned the lot both sides and drenched it in petrol after to clear all the excess stripper.
End result,...not bad, ready for a bit of welding soon.
#68 minimuk
minimuk
  • 1,947 posts
Posted 05 August 2011 - 10:12 PM
This afternoon had an hour to work on the rear panel, after cleaning all the paint of a few days ago, I invested in some KURUST........
the following picture will explain where I used the Kurust.
Got a few corner repair panels from Mini-Machine, always helpfull people there, the O/S needs a full repair piece while the nearside is not that bad, just the ledge +30mm.I marked the corners so any luck tomorrow I will cut and tack on the panels.
Attached File  DSC01993a.jpg   54.68K   11 downloads
#69 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 05 August 2011 - 10:16 PM
Good work, if I were you i'd be starting to plan the one after this now!
The rear corner bits are a pretty awful panel, I like to use the full heritage lower panel, bit more expensive but fits nicely.
#70 minimuk
minimuk
  • 1,947 posts
Posted 05 August 2011 - 10:35 PM
Shifty, yes I am planning the next one already,..........'61.......
when you say awfull. I assume you mean the curb is not perfect? I know the heritage panel would be a perfect straight fit but at a cost as you say, I will think about it this weekend.....might have to sell sommit first.
#71 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 05 August 2011 - 10:42 PM
Yeah, its a pretty awful panel. Looking at your donor panel the bumper lip looks a bit ropey as well. May as well just cut the crappy bits out and stick new metal in. It will be easier and look nicer that the two end panels.
A '61 you say.......I may have pop over and investigate...!!
#72 minimuk
minimuk
  • 1,947 posts
Posted 05 August 2011 - 10:51 PM
I see what you mean, repair rather then replace.Food for thought, thanks.....my idea was to put in first the corner's ,mould them to have a nice bend, so to speak, then cut the remaining lip away and weld a new lip(make a template first).
by the way Minimachine full width will be about 75 notes.
Edited by minimuk, 05 August 2011 - 10:52 PM.
#73 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Posted 05 August 2011 - 10:54 PM
Hey, when it comes to spending other peoples money, I'm always happy to help!!
#74 minimuk
minimuk
  • 1,947 posts
Posted 05 August 2011 - 11:00 PM
Now, why did I not think about that one first,...honestly, I have been looking for those full bottum repair panels but pricing of panels have gone rather crazy in the last 3 years. I will have a go at repairing the corners first, other half will be loving a bit of matal bashing over the weekend,...do I care......
Edited by minimuk, 05 August 2011 - 11:22 PM.
#75 minimuk
minimuk
  • 1,947 posts
Posted 07 August 2011 - 08:00 PM
took your advice Shifty, repairing the bad bits.
spending a lot time of templates making today, then again result shows, patience required and cups of tea.
first the nearside bottum corner
Attached File  DSC02001a.jpg   52.74K   9 downloads
then the lip
off-side corner still to do, panel beating with hammer and dolly first and see how it comes out. then decide what to cut out appart from the lip that needs replacing
after the corner is finished and the new lip is on, I will make the bumper bolt holes and sand back the lip back to 22mm between the bumper bolt holes.
Edited by minimuk, 07 August 2011 - 11:59 PM.
