Total Rebuild Of '71 Evy
563 replies to this topic
#526 minimuk
minimuk
  • 1,947 posts
Posted 03 January 2015 - 06:45 PM
started at 2pm at +4c in the garage, just got in when temp was reading +1c......so progress...off-side door had it's final fitting today, made good hinges out of old ones, less give so door is steadier, had a cuppa, and got back at it, my mate. dropped of some bread-tray trolleys, so Evy is now on skates....much easier to move around. Nearside door was next, easy fit and in no time all was lined up, so as a bonus, that door got re-skinned first, it had been 4 years when I did MUK's doors so after a visit in my memory lane, skin was on in 20 minutes, but that was with the handy tool from Sean Shifty Whitfield, Yep it is a 'Flanges bending tool', this guy has all the tools you need for flanges....lol here are a few pics from the door. finish welds tmz and give that door a coat of paint, then back on the off-side door...
off-side door fitting;
Attached File  final trial fit skins 3.jpg   38.39K   10 downloadsAttached File  final trial fit skins 2.jpg   17.72K   6 downloadsAttached File  final trial fit skins 1.jpg   172.61K   19 downloads
Nearside door re-skinned;
Attached File  Skin on 2.jpg   36.61K   8 downloadsAttached File  Skin on 3.jpg   123.96K   5 downloadsAttached File  Skin on 1.jpg   124.77K   2 downloads
Progress finally ;D
#527 minimuk
minimuk
  • 1,947 posts
Posted 04 January 2015 - 02:11 PM
so the story of the Evy's doors continue,...sanded back tack welds on the nearside door, and gave it sum what primer, for now, looks ace, then off side door, was a good fit so out came Sean's wicked magic tool again after upwards tapping to get the flange at a 45 degree angle, flange tool after, seam sealed and tack weld the top ends, whoosah done...the doors are re-skinned.....
I thought  to put some more detailed pictures up here
start to finish;
Attached File  re-skinning 1.jpg   131.56K   9 downloadsAttached File  re-skinning 2.jpg   103.07K   8 downloadsAttached File  re-skinning 3.jpg   116K   9 downloadsAttached File  re-skinning 4.jpg   106.66K   8 downloadsAttached File  re-skinning 5.jpg   30.32K   8 downloads
both doors re-skinned;
Attached File  re-skinning 6 jpg.jpg   132.41K   7 downloads
;D
#528 minimuk
minimuk
  • 1,947 posts
Posted 05 January 2015 - 04:06 PM
so I did spend a few hours in the garage, wanting to look at A-panels fitting....ended up lining up the whole front end for welding, using self-tappers to keep it in place, I think the flanges and gaps are as tight as a nun's......apart from the nearside door gap at the B-post, a few shims will do the trick there I hope, any thoughts....
Scuttle ends
Attached File  final fitting, and self-tappers in 1.jpg   109.21K   17 downloadsAttached File  final fitting, and self-tappers in 2jpg.jpg   164.47K   11 downloads
bonnet gaps
Attached File  final fitting, and self-tappers in 4pg.jpg   180.83K   10 downloadsAttached File  final fitting, and self-tappers in 5pg.jpg   177.7K   8 downloads
nearside door fit
Attached File  final fitting, and self-tappers in 2.jpg   173.09K   15 downloadsAttached File  final fitting, and self-tappers in 6pg.jpg   158.98K   12 downloads
bonnet lip to front panel
Attached File  final fitting, and self-tappers in 7pg.jpg   116.79K   5 downloads
welding tmz ;D
#529 minimuk
minimuk
  • 1,947 posts
Posted 06 January 2015 - 04:25 PM
and so the story continues, scuttle end stiffener plates welded in place, offered wings again, tiny adjustment for the better and cranked up the welder again, plug-welded wings to the inner-wing flanges and dressed the welds after, followed by a good bitta seam-sealed, dressed the scuttle to window flange and seam sealed those, enough for today......maybe a bit more tonight.....
Attached File  wings welded 1a.jpg   206.77K   14 downloadsAttached File  wings welded 1.jpg   193.46K   10 downloads
she is finally taking shape ;D
#530 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 06 January 2015 - 06:37 PM
Good work mate, coming along now :thumbsup:
#531 minimuk
minimuk
  • 1,947 posts
Posted 06 January 2015 - 08:35 PM
Thanks, yes it does Alex, finally taking shape now, on the last hurdle ,body-wise........ :proud:
#532 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2015 - 05:01 PM
and so it goes on, Nearside door fitted, A-panel welded in position, all looks good exept door skin surround needs widening on A-post B-post and bottom......that will be another day ....
door fitting, and gaps;
Bonnet offered and looks tidy;
offside tmz hopefully :shifty:
#533 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2015 - 05:05 PM
ordered some copper welding rod's and some cold front  to do the door skin edges, that will be an interesting job for sure....
Edited by minimuk, 07 January 2015 - 05:08 PM.
#534 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2015 - 07:16 PM
few pics of the above,
Attached File  final bonnet right 1.jpg   30.73K   7 downloadsAttached File  final bonnet left 1.jpg   26.38K   5 downloadsAttached File  near side final fit 2.jpg   148.76K   11 downloadsAttached File  near side final fit 3.jpg   189.11K   8 downloadsAttached File  near side final fit 1.jpg   109.06K   14 downloads
Edited by minimuk, 07 January 2015 - 07:17 PM.
#535 lourens
lourens
  • 84 posts
Posted 07 January 2015 - 08:21 PM
Working hard I see muk , keep going strong mate looks great !!!!
#536 minimuk
minimuk
  • 1,947 posts
Posted 07 January 2015 - 08:31 PM
Well thank you Sir, it was about time for some progress, last 2 month was very slow indeed as work was busy, a few more days on er and most welding is done....hopefully
#537 minimuk
minimuk
  • 1,947 posts
Posted 08 January 2015 - 02:07 PM
final weldatrol day,front end on,  off-side A-panel and wing done, door fitted, bit of attention to door skin and a few other bit's but happy as is, has been a good run....comments welcome.... ;D
Apanel to wing and A-post;
Attached File  off side Apanel and wingr final fittet 1a.jpg   188.65K   4 downloadsAttached File  off side Apanel and wingr final fittet 1.jpg   134.09K   7 downloadsAttached File  off side Apanel and wingr final fittet 2.jpg   161.48K   7 downloads
door fit;
Attached File  off side door final fittet 3.jpg   117.98K   2 downloadsAttached File  off side door final fittet 2.jpg   133.37K   4 downloadsAttached File  off side door final fittet 1.jpg   77.05K   7 downloadsAttached File  off side door final fittet 4.jpg   30.8K   6 downloads
looking good
#538 minimuk
minimuk
  • 1,947 posts
Posted 14 January 2015 - 07:42 PM
now the welding is nearly don I have started on the engine, found the culprit in the remote box,....fork is worn....so that one needs to be taken apart, block cleaned, checked bores, honed bores painted BMC Green, piston rings taken of the piston crowns cleaned, big ends need replacing and Main baerings to as the engine had a serious case of oil starvation, I did found that there was no rubber washer/seal between box nd block hence bad circulation and consequently main bearings coating was completely worn of to copper color, cam bearings are good, oil pump needs replacing, other then that block is fine.....cylinder head tmz
block and box
Attached File  block and box.jpg   197.01K   2 downloadsAttached File  crank shaft 4jpg.jpg   123.95K   1 downloads
honed bores
Attached File  cylinder bore 2.jpg   117.3K   11 downloadsAttached File  cylinder bore .5.jpg   21.2K   4 downloads
Attached File  cylinder bore 3.jpg   28.83K   5 downloads
painted 1st coat
Attached File  block painted 3.jpg   110.12K   6 downloads
shopping list for bearings rings pump etc..... ;D
#539 minimuk
minimuk
  • 1,947 posts
Posted 12 April 2015 - 05:57 PM
a few month have passed, work is busy so slow progress on the engine, but getting there slowly....
#540 minimuk
minimuk
  • 1,947 posts
Posted 12 April 2015 - 06:06 PM
new mains after crack re-grind, new big ends, timing sprockets and chail, tappets seals, new piston rings....gonna be a beauty
Attached File  crank trust washer movement set up.jpg   130.68K   4 downloads
Attached File  new main bearing shells in and lubed.jpg   130.65K   6 downloadsAttached File  centre main cap on and torqued for clearance reading.jpg   131.02K   7 downloads
Attached File  pistons in 1.jpg   120.97K   6 downloads
Attached File  rocker assembly cleaning 4a.jpg   126.96K   3 downloads
gearbox near stop..... ;D
