Total Rebuild Of '71 Evy
563 replies to this topic
#511 minimuk
minimuk
  • 1,946 posts
Posted 30 October 2014 - 04:15 PM
As you seem to do lots of measuring, can you recall how long a mini is without the front end? I want to move my project from the barn to the garage but I only have half a garage not sure if I can shoe horn it in :)
I can check in a mo, rear valance to blukhead .....or rear valance to front subby without the front end?
#512 mini_matt_106
mini_matt_106
  • 592 posts
Posted 31 October 2014 - 01:37 AM
Sorry I missed your reply, if you have both that would be great, I may have to try and gain a few feet in the garage
#513 minimuk
minimuk
  • 1,946 posts
Posted 31 October 2014 - 02:56 PM
first time after 4 years,given Evy some fresh air, trial fitted the front end using 2 clamps inside the light flanges and one on the nearside scuttle, and all fits just lush.....
Attached File  102_0323 1.jpg   150.46K   12 downloads
#514 minimuk
minimuk
  • 1,946 posts
Posted 31 October 2014 - 03:10 PM
Rear valance flange to bulk-head innerwing stiffener 245cm, Rear valance flange to front subby  minus front panel 280cm
#515 mini_matt_106
mini_matt_106
  • 592 posts
Posted 31 October 2014 - 05:23 PM
Thanks!! I'll get the measuring tape out :)
Nice to see her out in the sun! Your gaps look great *cheeky*
#516 minimuk
minimuk
  • 1,946 posts
Posted 31 October 2014 - 06:32 PM
 Cheeky gaps indeed, glad I choose genuine Heritage panels  ;D
#517 mini_matt_106
mini_matt_106
  • 592 posts
Posted 31 October 2014 - 07:41 PM
Turns out my garage is 10ft x 10ft!! Win!
Yes heritage panels are awesome! The amount you have to mod patern parts to make them fit makes it worth the extra!
#518 Risky
Risky
  • 213 posts
Posted 01 November 2014 - 09:28 AM
Looking good - it really it a total rebuild!
I've used non-heritage A-panels... They were a pain to fit!
#519 minimuk
minimuk
  • 1,946 posts
Posted 01 November 2014 - 04:24 PM
 Hi, long time no see, yes total resto, to be honest there was not a lot of steel on that mini when I bought it, I have used pattern panels for the floor only, the rest is Heritage, because it saves time and has a better finish...and she deserves the best  ;D ,
Just checked yr tread about your mini, all welding done, back on the road,soon by the looks of it....
Edited by minimuk, 01 November 2014 - 04:27 PM.
#520 Risky
Risky
  • 213 posts
Posted 02 November 2014 - 04:39 PM
Yes long time no see, been busy with my job!
Original/heritage panels are very nice, but they are very pricey in my opinion!
#521 minimuk
minimuk
  • 1,946 posts
Posted 24 November 2014 - 08:30 PM
moving on....taken original doors apart and repaired bottom flanges and corners, gave 2 coats of Por15 and sprayed inside skin after with topcoat, sound proofing tmz and then offer skin to door with a bitta seam sealant.....
Attached File  inside offside door.jpg   59.3K   10 downloads Attached File  offside skin.jpg   53.92K   5 downloads
fetling on ;D
#522 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 24 November 2014 - 08:48 PM
Good work mate
#523 minimuk
minimuk
  • 1,946 posts
Posted 26 November 2014 - 10:25 PM
and the next door, not as good to start with as it is rather coated with surface rust and some worse patches...onwards and upwards
skin taken of...
Attached File  102_0350.jpg   121.71K   11 downloadsAttached File  102_0349.jpg   130.33K   8 downloads
after a good clean por15 on the good bits
Attached File  102_0355.jpg   124.89K   7 downloadsAttached File  102_0357.jpg   125.69K   10 downloads
window seal boxing repair...
Attached File  102_0353.jpg   113.79K   13 downloadsAttached File  102_0360.jpg   178.53K   8 downloadsAttached File  102_0361.jpg   155.6K   13 downloads
bottom door repair panel on tmz and repair window seal boxing.... ;D
#524 minimuk
minimuk
  • 1,946 posts
Posted 02 December 2014 - 02:19 PM
Had a good welding day today, nearside door bottom flanges repaired and window boxing done, seamsealed the lot and maybe Por15 tnte, skins on soon
hinge corner
Attached File  hinge corner 1.jpg   121.08K   7 downloadsAttached File  hinge corner 2.jpg   123.68K   5 downloadsAttached File  hinge corner 3.jpg   126.05K   2 downloads
door lock corner
Attached File  bpost corner 1.jpg   125.22K   4 downloadsAttached File  hinge corner 4.jpg   128.53K   5 downloadsAttached File  hinge corner 5.jpg   48.94K   4 downloadsAttached File  hinge corner 6.jpg   126.88K   7 downloads
window box
Attached File  window boxing 4.jpg   124.71K   5 downloads
getting there ;D
#525 minimuk
minimuk
  • 1,946 posts
Posted 03 December 2014 - 04:29 PM
door finished with 2 coats of Por15, happy with that ready for skinning
Attached File  Por 15 1.jpg   152.46K   2 downloadsAttached File  Por 15 2.jpg   35.49K   1 downloadsAttached File  102_0340.jpg   21.16K   2 downloads
