Total Rebuild Of '71 Evy
563 replies to this topic
#31 minimuk
minimuk
  • 1,946 posts
Posted 11 February 2011 - 10:28 PM
Today I suppose to start on the nearside flitch and scuttle panel, thought I'd finish the offside first
started with zinc priming first, then made a template
Attached File  DSC01638a.jpg   20.54K   42 downloads
copied template on 1.2mm steelpanel, tacked, then seamed
Attached File  DSC01640a.jpg   19.75K   43 downloads
sand the weld back flush as possible and primed the lot again. looking good!
Attached File  DSC01641a.jpg   18.74K   54 downloads
Managed to get a full scuttle panel (magnum panels) today as the old one is shot, I can start on that when the nearside flitch and innerwing is tidy. Probably start tomorrow on that.
#32 minimuk
minimuk
  • 1,946 posts
Posted 12 February 2011 - 11:23 PM
Took off the rusty lower windscreen panel
cleaned bulkhead with parafin and scraped all the old sealant away
Attached File  DSC01642a.jpg   25.94K   29 downloads
and the rust came alight again, left above crossbar
Attached File  DSC01643a.jpg   23.04K   23 downloads
right near bonnet hinge
Attached File  DSC01644a.jpg   26.21K   15 downloads
after a bit of grinding/sanding with flapdisk and wire brush it does not look that bad
Attached File  DSC01645a.jpg   24.01K   23 downloads
will need to cut out the rusty parts and weld new panels in, before starting on the nearside flitch panel, another day perhaps.
#33 minimuk
minimuk
  • 1,946 posts
Posted 14 February 2011 - 06:58 PM
a bit of progress today, cleaning the garage and ended up welding
marking and cutting
Attached File  168992_10150189290926040_723241039_8926134_1512686_na.JPG   41.41K   36 downloads
fitting, tacking and welding
Attached File  182597_10150189291101040_723241039_8926142_7970659_na.JPG   40.54K   26 downloads
grinding and priming
Attached File  181948_10150189291231040_723241039_8926143_1122389_na.JPG   38.72K   28 downloadsAttached File  168927_10150189290831040_723241039_8926127_5988236_na.JPG   36.77K   40 downloadsa.JPG]
I am happy with that
#34 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 14 February 2011 - 07:35 PM
And you should be happy minimuk - great work. I'm following with interest as you are working at the same area as me - but much faster! Keep up the good work.
Hugh
#35 minimuk
minimuk
  • 1,946 posts
Posted 14 February 2011 - 09:08 PM
Hugh
Thanks Hugh, but you got to keep up,... I am not doing any work on it tomorrow so you can catch up!! Back on it on Wednesday,....other side and flitch panel. Well that is the plan!
#36 minimuk
minimuk
  • 1,946 posts
Posted 15 February 2011 - 09:43 PM
I could not resist to show you this, Just a few quick pictures taken today from my first project, my '81 mini at the painters, blue paint primer is on ,....finally spraying tomorrow fab!!
one years work coming to an end.
Edited by minimuk, 15 February 2011 - 11:22 PM.
#37 minimuk
minimuk
  • 1,946 posts
Posted 16 February 2011 - 08:20 PM
Today I did some tidying up of the lower window panel, drilled the old spotwelds and took of the remaining strip of metal which I left on a few days ago (should have taken it of then really)
Cut out and weld in a new strip on the top dash lip
grinding it down to size and flatten the weld
repair piece done, sanding down whole of lip and primed the lot
cut out the top inner wing rust panel and replaced, grind and cleaned to bare metal
Attached File  DSC01660a.jpg   17.74K   17 downloads
zinc primed it, and the top flitch panel too.
time passes quickly when you have "fun", never started the flitch panel today, to much faffin about with bit's today and priming the new panel bits inside the car too, seam-sealing tomorrow I hope. Back to it on Friday and might Brace the nearside door frame so I can remove the door post and old rusty flitch.
But............getting there...
Edited by minimuk, 16 February 2011 - 08:22 PM.
#38 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 17 February 2011 - 08:52 PM
So recognisable. where you are working! Yours is a bit less rusted than mine. Lovely repairs.
Hugh
#39 minimuk
minimuk
  • 1,946 posts
Posted 17 February 2011 - 09:46 PM
Hugh
thanks, I just found out that my other mini was sprayed today, need to make some space in the garage soon<.....OMG... but also need to do the flitch panel before that happens!! Pressure is on!!
Edited by minimuk, 17 February 2011 - 11:27 PM.
#40 minimuk
minimuk
  • 1,946 posts
Posted 19 February 2011 - 12:02 AM
Have to put Evy on the back burner, just got my other mini back and needs to finish him first so I have some more space in the garage.
Evy is at the back in the cramped garage havin a nap or 2,...
2 month perhaps, then again if the weather clears and have some sunshine, I can move 850X out for fresh air and carry on with Evy.
So in a way I haven't forgotten about her and is in the hand of the gods!
You can follow Project 850 X for the time being.
Edited by minimuk, 25 February 2011 - 11:01 PM.
#41 minimuk
minimuk
  • 1,946 posts
Posted 10 March 2011 - 05:50 PM
well, it has been a while, I am to much pre-occupied with Project 850X at the moment, But today I was in a welding/cutting mood, so thought I might aswell start on the N/S doorpost total replacement, and new flitch panel.
How it was a few weeks ago
Attached File  DSC01567a.jpg   26.06K   14 downloadsAttached File  DSC01659a.jpg   22.46K   14 downloads
Today after measuring all directions cut and grind back ready for new panels tomorrow,...I hope
Attached File  DSC01676a.jpg   24.31K   41 downloads
This is a bit more rough work rather then delicate finishing of project 850x, all fun!!
Edited by minimuk, 11 March 2011 - 04:46 PM.
#42 Pitcrew6464
Pitcrew6464
  • 1,673 posts
Posted 10 March 2011 - 07:43 PM
Cool project! HARDCORE :) lots of welding progressing well! love the paint job on your other mini, definatly have your hands full!!!
#43 minimuk
minimuk
  • 1,946 posts
Posted 10 March 2011 - 08:07 PM
thanks , I like the word "Hardcore", as I mentioned before, little jobs first on the other one, then you have to leave that, prior of making mistakes, then go back to the rough works, I don't know what is more enjoyable, either way it slows both down a bit. Keeping the bits separate and clearing space, sometimes takes more time. Have a cuppa now and then does help too.
#44 minidream94
minidream94
  • 1,233 posts
Posted 10 March 2011 - 08:18 PM
WOW nice project and work mate :) im currently trying to do my flitches but having done no bodywork before its very scary cutting ya car into pieces :s but your work is very good ^_^
#45 minimuk
minimuk
  • 1,946 posts
Posted 10 March 2011 - 09:48 PM
WOW nice project and work mate :thumbsup: im currently trying to do my flitches but having done no bodywork before its very scary cutting ya car into pieces :s but your work is very good :D
rule of thumb, make sure you have braced the mini, then...mearsure and measure,...mark your cutting line,.... measure again,....cut! see what will be next job near it,...tack it and seamweld it, flat sand it , prime it seamseal it prime it again,..job done. Go to next repair.
Good luck with your van, I try and put a few flitch piccies up tomorrow.
