Total Rebuild Of '71 Evy
563 replies to this topic
#421 minimuk
minimuk
  • 1,946 posts
Posted 18 September 2012 - 03:30 PM
Today is one of them days......a lot planned to do but........getting the engine bay sorted, seamsealing welds, scuttle panel on etc...
trying the scuttle panel to fit and weld,....FAIL....not heritage......hmph.....Minispeed sending one tmz,
tacked bonnet hinges in final position, so bonnet sits snog, no doubt all will be different with Heritage scuttle.....
on a positieve note, put first coat of Teal Blue (1970-1975) on bulkhead....
Attached File  bulkhead and innerwing first coat teal blue18-9 2.jpg   100.12K   25 downloads
see what brings us tmz ;D
Edited by minimuk, 18 September 2012 - 03:50 PM.
#422 ToM 2012
ToM 2012
  • 4,066 posts
Posted 18 September 2012 - 06:29 PM
looking really good mate whats hmph?
#423 minimuk
minimuk
  • 1,946 posts
Posted 18 September 2012 - 06:39 PM
meaning I should have known better.....then again I had the nongenuine scuttle in the corner of the garage,just does not look right....
#424 ToM 2012
ToM 2012
  • 4,066 posts
Posted 18 September 2012 - 06:58 PM
if you would like to sell any panels you done want i will be happy to buy them off you. as i need some for my other mini mate
#425 grahama
grahama
  • 2,442 posts
Posted 18 September 2012 - 07:00 PM
Very nice Muk.
Like the colour and the work. How did you find out the location position of the bonnet hinge mounts?? Just incase I want to go back to them later !!
Graham
#426 minimuk
minimuk
  • 1,946 posts
Posted 18 September 2012 - 07:22 PM
Very nice Muk.
Graham
Graham, location position was in my notepad and pictures, when I removed the old ones from the rotten panels, if you need them in the future, I will let you know.
#427 minimuk
minimuk
  • 1,946 posts
Posted 19 September 2012 - 03:23 PM
and a bit more done......
Attached File  bulkhead and innerwing first coat teal blue18-9 3.jpg   106.74K   32 downloads
dropping subby tmz and give it a few coats behind it.....still waiting for scutle panel >_<
#428 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 19 September 2012 - 09:27 PM
looking good now mate
#429 minimuk
minimuk
  • 1,946 posts
Posted 21 September 2012 - 09:58 PM
cheers Wayne, a long way to go but in a straight line.......
playing with the new heritage scuttle/lower window panel, only got one shot so tweeking with innerwing to bulkhead panel to get all lined up. Happy with result, tacking tmz possibly, unless I fettle a bit more on it, but got be be 410mm spot on between top and bottum lip at any place.
panel positioned
Attached File  scuttle panel fit 1.jpg   42.52K   19 downloads
need to tidy innerwing to scuttle a bit
Attached File  offside scuttle fit 1.jpg   36.71K   27 downloads
same here
Attached File  neaside scuttle fit 1.jpg   23.99K   18 downloads
when little jobs done panel will be tacked in place,......SPOTWELDING SOON, Graham....but after scuttle, wings lining-up......can't wait for that ;D
#430 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 22 September 2012 - 07:14 PM
Looks so good. You are so wise I shouldn't suggest this. I didn't check if the windscreen fitted before welding up my screen surround with scuttle. Of course it didn't fit so I had to grind out the aperture. You advised me to take it all back out and do it properly. Just jogging your memory.
Hugh
#431 minimuk
minimuk
  • 1,946 posts
Posted 22 September 2012 - 08:12 PM
Hugh
well Hugh, funny you say that, I was thinking about you when writing last piece, as mentioned before, slow but in a straight line, one day won't matter that much, will save that in the end....hopefully. Further it is so much nicer to work with Heritage panels for the very visuable body-work, it just all fit's !!
#432 minimuk
minimuk
  • 1,946 posts
Posted 01 October 2012 - 04:59 PM
after one week no play, as work was to busy last week, got back on her.
first a dry run with the wing's and scuttle gap's,
happy with the looks of those;
Attached File  scuttle panel wing nearside fit 1.jpg   88.48K   19 downloads Attached File  scuttle panel wing off-side fit 1.jpg   88.6K   21 downloads
after that, the final scuttle panel and inner wing's prep, this is a slow process as all has to be measured 10ish times, here are a few measurements for the professors on here; window middle under gutter to middle scuttle gutter edge 21", under roof gutter nearside and offside to scuttle gutter edge above the bonnet hinges 213/8".
Once this was achieved, 2 hours later, I finished the innerwing/scuttle crossover to bulkhead. then zinc primed and a good coat of Teal blue.
work tmz but Wednesday another go at it, selftappers galore..... ;D
#433 markje
markje
  • 183 posts
Posted 01 October 2012 - 05:33 PM
Looking great
#434 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 01 October 2012 - 06:48 PM
Minimuk you should be satisfied with wing/scuttle gap - they are perfect!! That is some job you've done to the front.
Hugh
#435 minimuk
minimuk
  • 1,946 posts
Posted 01 October 2012 - 07:30 PM
Looking great
Cheers Markje, still a long way to go....
Hugh
Thanks Hugh, the most important panel for lining up all front panels in my opinion is the scuttle, if that is wrong all is out...the wings where only trial fitted so the end result should be good, once propper clamped and tacked hear and there. I will offer the bonnet on Wednesday too and see where we are.....
