Total Rebuild Of '71 Evy
#376
Posted 03 August 2012 - 05:44 PM
Hugh
#377
Posted 03 August 2012 - 08:30 PM
#378
Posted 03 August 2012 - 09:00 PM
#379
Posted 03 August 2012 - 09:14 PM
going well there matey ( i will get you to do the mexico for me ) ha ha
lol.....now that would be a challenge.....
#380
Posted 04 August 2012 - 01:37 PM
you must have shares in the POR company lol. Very nice repair, so glad I didn't have to all those fiddly bits.
Graham
#381
Posted 04 August 2012 - 09:47 PM
Hi Muk,
Graham
lol Graham,....becoming a rep soon, tin number3 starting soon on subby......it is slow but satisfying repairs, they are each a piece of the puzzle, just getting them in the right place and order takes time but results are good
#382
Posted 04 August 2012 - 09:58 PM
first innerwing to cross-member plate tacked in position;
then plug welding and sanding back the welds;
stiffener to cross-member and to innerwing plate ;
tonights Por15 coat;
looking fab.
give it a good clean tmz, and get it ready for a primer coat
Edited by minimuk, 04 August 2012 - 10:01 PM.
#383
Posted 05 August 2012 - 07:28 PM
all looks good in the picture...BUT FAIL
so back to looking like this
when last bit of subby is finished, I will use that als alingning tool bolt all up and in place and then weld it, I won't be beaten.....
#384
Posted 05 August 2012 - 08:48 PM
gutted for you pal, but I thought I had welded the entire front end on too short till I realised I had trapped the battery cable betweem the subby and steering rack !! I am sure you will sort it tho.
Front subby looking good with the electrolysis. Such a good method of rust removal, but when you paint it up remember to leave bolt holes as the clearance is very tight and I ended up scraping all the paint out of mine so the bolts fitted !! Lots od grease followed !!
Graham
#385
Posted 13 August 2012 - 03:26 PM
electrolises on subby done..... cleaned it of, then used Por Metal Prep and washed it of after 10 minutes and then....u guessed
a good 1st coat of Por15.
subby cleaned off with metal prep and then yet-washed it
leaving it to dry in the 'sun'
Por15 1st coat
when finished I attach the end crossmember repair piece, pit the subby in position and do the welding then, to make sure all is alligned.
#386
Posted 13 August 2012 - 10:03 PM
I have got to get some por 15 next time, it has come up much better than mine with three coats of the dreaded hammerite !!
Graham
#387
Posted 13 August 2012 - 10:49 PM
Looking good Muk,
Graham
I have done a second coat tonight, one can either put a 3rd coat on, leave it and bolt it back on,.... or key the paint job with scotpad and spay topcoat on it, no need for primer.....but yes it does look good, I will put a 3rd coat on it tmz and make a few close-up piccies
Edited by minimuk, 13 August 2012 - 10:50 PM.
#388
Posted 14 August 2012 - 12:01 PM
#389
Posted 14 August 2012 - 02:59 PM
started on a mini cooper 1965 gearbox refurb because EVY's gearbox is caput..............
the mess;
diffy bits;
plotting on
Edited by minimuk, 14 August 2012 - 08:55 PM.
#390
Posted 28 August 2012 - 04:46 PM
worked a bit more on the '65 gearbox and soon is ready to be re-assembled.
few jobs done on the front cross-member repair end.
front subby back on soon and start to work on the front end a bit.....for alignments
