Total Rebuild Of '71 Evy
563 replies to this topic
#361 minimuk
minimuk
  • 1,946 posts
Posted 24 July 2012 - 05:42 PM
thank you Graham and Hugh,......what a day today I had on Evy, just wanted to finish the front roof repair.....
a bit more filling and sandin wiv 80-240-600grit
Attached File  front roof repair nearside filler and sanded 80grit.jpg   99.37K   12 downloads
etch primed
Attached File  front roof repair nearside filler and sanded 240 then 600gritetch primed2.jpg   91.06K   10 downloads
then I got steering colum and all that out, followed by the wiring loom after taking umpty piccies of the centre-speedo,.....which was seized, but after a 'little play' (1hour) all working again.
Dropped subby while I was at it..
Attached File  dropped subby.jpg   117.73K   9 downloads
Finaly a bit more rust
Attached File  off side toeboard bulkhead repair 1.jpg   108.06K   21 downloads
Edited by minimuk, 24 July 2012 - 06:11 PM.
#362 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,041 posts
Posted 24 July 2012 - 05:45 PM
Looking great :highfive:
Edited by alex-95, 24 July 2012 - 05:45 PM.
#363 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 24 July 2012 - 06:55 PM
I hate sanding with a huge hate! You've certainly been busy. Always more rust to find on a Mini.
Hugh
#364 minimuk
minimuk
  • 1,946 posts
Posted 25 July 2012 - 04:15 PM
after yesterdays interesting find(the rusty bit), I cleaned the engine side bulkhead and toeboard with paint removing disk, wire brushes and parafin.
then used Por Metal Prep to get a 'key 'on the metal;
Attached File  off side toeboard bulkhead repair 2a.jpg   99.14K   12 downloads
and gave it a good coating of POR15
Attached File  off side toeboard bulkhead repair 2.jpg   105.51K   17 downloads
I does not look that bad,.......appart from the panels not coated, they need replacing, including the end bulkhead crossmember bit >_<
#365 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 25 July 2012 - 10:28 PM
i have one of the lower door frame repair panels for the bottom, you can have it mate but not sure if its n/s or o/s give me a shout ?
Wayne it is the first one. offside which really had it, I will pay you for it as it has cost you b4, pm me yr paypal details and tell me the amount,if you have the one I need. cheers
Go for the repair panel Muk. I made sections to repair mine and the result I suspect would be far neater with the whole panel!! Just my experience.
Graham, I have done those repairs on MUK's doors, certainly challenging and a good learning curb for pannel making and welding, offside no good, and could do wiv a repair iece but the nearside is do-able always looks worse then reality....then again, don't really want to see it in the first place,....defo need new skins 4 sure ;D
PS, guys I feel it is going to be a garage day today, 'miss MUK' is going out 4 a bit,......... :highfive:
mate not got a paypal and it was only 10 quid . i will give it you no probs after all the help you give me !
#366 minimuk
minimuk
  • 1,946 posts
Posted 30 July 2012 - 09:58 PM
Had a bit of a busy weekend at work so back To Evy today and tmz.....
Off-side bulkhead-crossmember end needs sorting and the panels beind too, so here we go;
started electrolising front subby:
Attached File  electrolising front subby 1.jpg   113.56K   11 downloads
Bulkhead-crossmember repair
to start:
to follow:
to continue:
and a bit more:
Attached File  off side toeboard bulkhead repair 6.jpg   99.56K   9 downloads
and to finish for today:
Attached File  off side toeboard bulkhead repair 7.jpg   34.55K   10 downloads
can't wait for tmz......
Edited by minimuk, 30 July 2012 - 10:12 PM.
#367 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 31 July 2012 - 07:21 AM
Nice repair. Hope you get the rest done today.
#368 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 01 August 2012 - 09:02 PM
see you're workin hard again , l bet it's starting to look good now ?
#369 grahama
grahama
  • 2,442 posts
Posted 01 August 2012 - 09:35 PM
Electrolysing a subframe, thought only me was that daft. Come up a treat tho.
#370 minimuk
minimuk
  • 1,946 posts
Posted 01 August 2012 - 09:49 PM
well getting that welding bug again,......just never stops.......piccies to follow later
Close enough starting to look like a Lady again
Graham, electrolysing I have learned from you, front subby turned today and the first bit looks great
#371 minimuk
minimuk
  • 1,946 posts
Posted 01 August 2012 - 10:30 PM
well guyz, monday,yesterday and today a fab day in the office(garage) love it when a plan comes toghether, when looking at the last pictures, there are e few panels to make and rot to cut out, then you got to think in 3D,........the more complex the better, just like being against a champion Chess Player......
all rot cut out and carefully peeled back the bottum flitch panel lip to remove toe-board cut out;
Attached File  off side toeboard bulkhead repair 8.jpg   101.9K   14 downloads
in the end flitch panel lip was crap so cut that out to and made new flitch-lip, tacked with toe-board repair piece in position after the bulkhead repair panel was in position, cut cut measure measure.....:
Attached File  off side toeboard bulkhead repair 9.jpg   93.84K   20 downloads
made bulkhead panel piece to sit behind crossmember-end piece as that area was no-more....;
Attached File  off side toeboard bulkhead repair 11.jpg   43.32K   13 downloads
what was finished I coated quickly with Por15:
today I finished all the welds especially the toe-board and flitch lip which I seamed and sanded back, then done the inside and seamed on the joints and sanded that back.....Por15 over the lot again(never enough) and trial fitted the crossmember end piece from M-Machine, as you can see I used a broomhandle, used the subby tower bolt holes as template and drilled 4 holes at the correct position then dropped the subby bolts through it and used the excisting nearside bolt holes in the cross-member as reference point to work from
Attached File  off side toeboard bulkhead repair 13.jpg   69.06K   22 downloads
so the plan tomorrow is to fit the end pice and repair the inner wing stiffener.....
#372 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 02 August 2012 - 09:18 AM
That is quite a repair to the bulkhead and toeboard! Great. I'll be most interested to see your subframe after the electrolysis. I remember Graham doing it. A fascinationg process.
Hugh
#373 jagman.2003
jagman.2003
  • 1,307 posts
Posted 02 August 2012 - 11:53 AM
Great work, no more wet feet in the rain?
#374 minimuk
minimuk
  • 1,946 posts
Posted 02 August 2012 - 04:13 PM
Hugh, this just for you, spot the difference.......
Hugh
Cheers, lets hope so,...but at least it is strong again,....
#375 minimuk
minimuk
  • 1,946 posts
Posted 03 August 2012 - 04:16 PM
few bits done today, made/repaired bulkhead stiffener and welded cross-member end in position the Por15nd it
slowly but surely........
crusty.....
welded repair end
trial fit
Attached File  off side toeboard bulkhead repair 16.jpg   99.69K   18 downloads
Por15
Attached File  off side toeboard bulkhead repair 17.jpg   98.74K   16 downloads
