Total Rebuild Of '71 Evy
563 replies to this topic
#301 minimuk
minimuk
  • 1,946 posts
Posted 19 June 2012 - 02:22 PM
Definitely getting a spot welded for next project. Saves all the grinding back. Back end looking good.
Yep you are right there, I will get all lined up for the day(s) I have the machine, If it is a handy tool I might even buy one for my next project........
#302 minimuk
minimuk
  • 1,946 posts
Posted 20 June 2012 - 10:25 PM
Wayne,
final filling and flattening of the 4 main area's on the rear panel finished with etch-primer, verdict plz
Both lamp-holes 80-120-320-600grit finished and pinholes covered and flattened
Both rear panel gutter corners, same treatment as above
Attached File  rear panel final etch primer nearside gutter.jpg   94.31K   9 downloads
also filled the previous roof repairs and sanded back will finish those tomorrow and then......defo starting with the arches........and rear quarters :shifty:
#303 minimuk
minimuk
  • 1,946 posts
Posted 25 June 2012 - 05:26 PM
filling and sanding is ongoing, roof corner repairs.... thought I make a start on the full floor replacement B4 the arches, keep some stenght in the car.
cleared loose rust debreze out of the footwel and tunnel, appart from the obvious floor hole, I noticed a plate on the front tunnel area, covering the 'Magic wand' hole, the tunnel is a Mk2...and has also a remote gear change (alu box) hole for the origional engine, and when I got the car the was a rod change gear linkage in that hole....previous owner liked a bitta change now and then.....
as you can probably make out, the bottum 4" from the toe board panel needs replacing from flitch till just after the subby mounting, tunnel needs a good clean after the floor panel is cut out, then close up the Magic wand hole and weld on the fabricated toe board repair piece, cut out the crossmember half on the nearside and the rest of the rear floor.... cut new floor to fit....and bob's yr uncle....a bitta weldin...... In theory ;D
Edited by minimuk, 27 June 2012 - 11:26 PM.
#304 minimuk
minimuk
  • 1,946 posts
Posted 28 June 2012 - 03:55 PM
started to repair/replace footwell rot on nearside,
starting to cut out the front floor piece first.
although the main flitch panel was replaced I notice a bit more virus near the toe-board going up into the top corner that needed to be sorted, cut out 2 " strip and replaced with new piece, then I was able to cut out the bad toe-board piece and made a new piece 1.2mm thick steel.
Attached File  nearside footwell and tunnel 2jpg.jpg   111.12K   26 downloads
next tunnel repair and closing up the magic wand hole
Edited by minimuk, 28 June 2012 - 04:18 PM.
#305 grahama
grahama
  • 2,442 posts
Posted 28 June 2012 - 08:20 PM
Nice repair as usual muk. I take it you are just readying it for a complete floor to slot in in one go. Can't remember half or full floor?? Have you swapped engine to a rod change for the remote, seeing the hole is going??
Graham
#306 minimuk
minimuk
  • 1,946 posts
Posted 28 June 2012 - 10:04 PM
Graham
Thanks Graham,
full floor replacements on both sides, and yep readying at a steady pace, I must get Muk ready too for Himley Hall on the 8th July.
I only seal of the magic wand hole in the toe-board, planning to keep the old origional 1969 engine with the remote gear linkage(box). the refurb of that one in the winter. If that one is salvageble, If not I have a 1300 on stand by and I can always use the same remote hole and change that one into a rod-change (bitta welding needed). But that is far away yet.. :shades:
#307 minimuk
minimuk
  • 1,946 posts
Posted 30 June 2012 - 03:58 PM
only had 1 hour this afternoon, catering is a funny business........
anyhow tunnel repair;
before
Attached File  nearside footwell and tunnel 3pg.jpg   111.23K   15 downloads
inbetween;
Attached File  nearside footwell and tunnel 4pg.jpg   105.45K   9 downloads
after;
Attached File  nearside footwell and tunnel 5pg.jpg   111.85K   12 downloads
quick shower and back to work :gimme: ;D
#308 STREET TWEAKS
STREET TWEAKS
  • 662 posts
Posted 02 July 2012 - 08:06 PM
Wayne,
Hi mate sorry for the delay in getting back to ya been on my holl's for 2 weeks ,
that looks great matey very well done , and it looks as if you have been workin very hard keep it up
#309 minimuk
minimuk
  • 1,946 posts
Posted 02 July 2012 - 08:50 PM
Wayne,
Cheers Wayne, hope you had a good break, anywhere nice and hot?? well, I am just plotting on,1-2 hours a day, I do enjoy the filling bit,its reading the evenness that takes time to learn ........trying to get ready for Himley too,... floor-prep on Evy seems to take ages, all in good time.... ;D
Edited by minimuk, 08 July 2012 - 06:05 PM.
#310 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 03 July 2012 - 07:16 PM
You have certainly been busy since I last looked makes my shame even more!! Super work as usual.
Hugh
#311 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 04 July 2012 - 07:13 AM
Looking out for those wheels...!
#312 minimuk
minimuk
  • 1,946 posts
Posted 08 July 2012 - 01:16 PM
this morning we supposed to go to Himley Hall. cancelled again because of rain.......it has been sunny sinds 10am........
spend a bit of time finishing and dressing the toe-board.footwell repairs before moving on to cutting the 1/2 crossmember on nearside and rear floor.
seam welded the inner flitch to repair piece and seamed the tunnel repair piece, then sanded back and gave the whole area a good coating of Por15 before a layer of primer.
Attached File  nearside footwell and tunnel 7pg.jpg   113.67K   13 downloads
hopefully having a good run tmz at it
#313 minimuk
minimuk
  • 1,946 posts
Posted 09 July 2012 - 02:50 PM
I did say yesterday might have a good day today......I think so!!!
to begin
cut out the rotten floor and 1/2 crossmember
Attached File  nearside footwell and tunnel 9pg.jpg   107.78K   8 downloads
cleaned up the tunnel and looking for bad rust, cleaned surface rust
fitting the full floor, not easy as the companion bin makes it a tight fitting exersize. a bit tweeking and all in position, made weld holes for spotwelding and tighten all with cleco pins first
Attached File  nearside footwell and tunnel 10pg.jpg   106.37K   15 downloads
removed one by one the cleco pins and replaced those with self tappers to tighten the joint.
Attached File  nearside footwell and tunnel 11pg.jpg   115.72K   10 downloads
Attached File  nearside footwell and tunnel 12pg.jpg   112.63K   13 downloads
enough for today..... ;D
#314 ToM 2012
ToM 2012
  • 4,066 posts
Posted 09 July 2012 - 05:53 PM
looking really good minimuk doing a great job. can you tell me how to change my name a mini is reborn? thanks
#315 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 09 July 2012 - 06:24 PM
A lot of work for a day! Great
Hugh
