Total Rebuild Of '71 Evy
#196
Posted 27 March 2012 - 12:08 PM
Hugh
#197
Posted 27 March 2012 - 04:11 PM
Very nice repair to the parcel shelf. What hours of patient work. Like Graham says its methodical. I love watching your work and progress.
Hugh
Hugh all in good time,....
prepped rear panel's welding surfaces with Por metal ready and POR15, after removing the old lock catch,I washed the welding surfaces with metal ready
good coat of POR15, and did the joining surfaces on the car too.
that's all for today, only had an hour off this afternoon
#198
Posted 27 March 2012 - 08:43 PM
#199
Posted 27 March 2012 - 08:50 PM
very well done m8 your doin great , you had sum time off work then ???
Wayne, that is the problem, getting busy at work, so can only work an hour every day,.....however,...back in the garage tonight after getting home and give it a second coating of POR15
#200
Posted 28 March 2012 - 04:06 PM
inside of the rear panel has 2 coats now
outside I gave the critical areas a good coat including the petrol hole, to prevent dampness getting near the metal,...
A little panel bashing on the bottum section tmr or friday and panel is ready to be offered
#201
Posted 02 April 2012 - 03:32 PM
took me a while to get the positioning right
when in final position, plug holes done
plug weld the holes
sanded back
concentration gone but,.....she got a rear again
havent welded all the way down yet will weld gutter and under the gutter first, rear quarters need seeing to anyhow...
getting some life back in her....
#202
Posted 02 April 2012 - 07:24 PM
#203
Posted 02 April 2012 - 07:29 PM
#204
Posted 02 April 2012 - 07:39 PM
Great minimuk
Hugh
#205
Posted 02 April 2012 - 08:04 PM
Nice one !! Great day's work lining up and plugging, looks like a mini again. Is it ok along the boot lip aswell??
Boot lip was re-done a few month ago, weel treated with Por15 amonghst other things, need to drill a few holes for the offside boot lid hinge, lining up certainly takes most of the time, plugging is not to bad,looks good, am happy sofar....
nice work mate keep it up. just a fort will the petrol tank go in place? cheers tom
I have left the tank hole in it's origional place, I might change that by having a boot floor tank fitted,.....
That is quite a piece of work!!! Looks really nice. It is a huge amount of work plug welding - drilling, welding grinding. I wish I had been rich enough to buy a spot welder!! But it is satisfying.
Great minimuk
Hugh
Thanks Hugh, it takes time but I am in no rush with this one, I am not so sure buying a spotwelder would help, happy to use the MIG, drilling holes takes more time, but hole puncher helps
#206
Posted 02 April 2012 - 08:20 PM
#207
Posted 09 April 2012 - 08:34 PM
#208
Posted 09 April 2012 - 09:06 PM
#209
Posted 09 April 2012 - 09:46 PM
hi mate can you post sum close up pics of the hing panel and the lamp panels plzs where you welded them together just for me
I pm you some, when doing the job a few month ago
#210
Posted 24 April 2012 - 03:14 PM
few piccies from recent repairs
rear panel to gutter;
rear panel to parcel shelf and roof stiffener;
see you next
