Total Rebuild Of '71 Evy
#166
Posted 18 March 2012 - 09:04 AM
#167
Posted 18 March 2012 - 03:45 PM
lookin good mate , give me a shout when your doin the back end
at some point next week,.....pending on work, bracing first!!!
#168
Posted 18 March 2012 - 08:00 PM
#169
Posted 18 March 2012 - 08:32 PM
seen a full back panel new today on ebay for about £50 mark thinking of getting it for my mini , but got the hing panel and lamp panels now what you think ????
seen that panel 2. £50 is very cheap as new is about £180
http://www.ebay.co.u...=item1c24eff5b4
still a few days to go on that, so wait a bit not bidding is good, wait till end and hit it with yr highest bid, other than that stick with your origional plan.
#170
Posted 19 March 2012 - 02:12 PM
Glad to see you’re getting on with it.
Cheers.
#171
Posted 19 March 2012 - 04:09 PM
First Barcing the rear end, but where.....used top of the arches and crossed through rear bulkhead to the existing cross-bracing this should keep all in place till new donor panel is fitted....
sanded back the paint on window seal lip for plugwelds
Drilled plugwelds out,
used angle grinder with 1mm cutting disk to do the honours, no wonder there was no spare wheel
inspecting bits to do, nearside guttering plus stiffener needs a 10" replacement
other that that but surface rust here and there,and a bit of repairs on the parcel shelf lip in corners.
just to make sure......
might sell this one on fleabay
thats it for today, every day another step, gutter repair tomorrow perhaps
#172
Posted 19 March 2012 - 05:07 PM
More gutter repairs, but then you are used to them now !! Nice work as ever.
Graham
#173
Posted 19 March 2012 - 05:31 PM
Well, it's a while since someone had a boot as crappy as that on a build !! I see the bash on the old rear panel, but did you replace the lot because it is easier than smaller repairs, as a lot of it looks fine ??
Graham
Graham, to be honest the old panel ha a lot of hidden rust but still covered with paint, the bash was not repairable even with dollies and hammers, I did try but in the end it would be a complete patch up of a panel, top and bottum and not worth the time and efford,...the donor panel is good and will be prepped to his new position in a few weeks. All little repairs first and Por15 here and there,......
#174
Posted 19 March 2012 - 06:38 PM
I used electrolysis on most of the smaller parts on my project. Learnt it off a mate that did most of his Alvis TA14 with it, even the front wings! lol
Regards, Duncan
#175
Posted 19 March 2012 - 08:04 PM
Just found your project buddy, great job! Your repair panels on the roof and gutters are fantastic, you must be chuffed? Look forward to the end result.
Regards, Duncan
Cheers Duncan, appreciate your comments, this project is just fab, bout 3 hours a day and ye think yr there,.....no chanse in that,.... and then start again.
Electrolysis is indeed a great way to clean and preserve good old usable bits you need again when reassembling, will safe a few bob.
Still need to do her engine and will go the same way in the bucket...
#176
Posted 19 March 2012 - 08:59 PM
#177
Hugh
#178
Posted 20 March 2012 - 04:54 PM
nearly forgot to make a piccy for yuz
rot cut out
fabricate new piece with cut out as template
fin's cut into lip to get a smooth curve, fin's will be welded shut again after
that's it for today
#179
Posted 20 March 2012 - 09:26 PM
#180
Posted 20 March 2012 - 09:40 PM
