Total Rebuild Of '71 Evy
563 replies to this topic
#151 minimuk
minimuk
  • 1,946 posts
Posted 03 March 2012 - 05:10 PM
Can't beat a bit of bracing but is it required on the rear panel?? Are you replacing the bottom bit where the boot hinges to or the whole panel?? If the later I would be bracing! Really glad my roof is, as far as I have looked, good, as it looks a nightmare to do !!!
Will really have to summon up some enthusiasm soon !!
Graham
hi Graham, it is the whole rear panel check out page 1 and 7, Evy had a bash at her rear, wasn't me this time,... ;D
#152 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 03 March 2012 - 06:33 PM
That is one amazing roof repair!
Hugh
#153 grahama
grahama
  • 2,442 posts
Posted 03 March 2012 - 10:41 PM
i agree Hugh and sorry Muk, missed the bash, brace my man, brace !!
#154 minimuk
minimuk
  • 1,946 posts
Posted 04 March 2012 - 04:59 PM
started cutting the O/S rot out,...used my chargable Dremel,
as you cans see, an old stressed out one,.....
1 inch with diamond blade and charge was gone, used cutting disk on angle grinder instead and finish with Dr Dremel to cut near the gutter
might have to open my wallet and get a new ish dremel, I wonder if the Dremel 300 will do??
#155 minimuk
minimuk
  • 1,946 posts
Posted 05 March 2012 - 05:40 PM
only a small contribution today,.....other half wanted me to paint the bath room for ages, was getting a bit deaf on one ear, so paint from B&Q and managed to put 2 coats on, one more tomorrow, to keep the peace,.....for now ;D
went back to the front roof repair on driver side, Dremel Charged again and out with it,....
a little surface rust on the inside, was expecting worse than that, just done the other side and that was a bit further then just rust, will give that a good clean out and use 'metal prep' and 'por15' for a change.
found an old front wing piece from MUK, that will do the job for a new corner piece, progress tomorrow hopefully (after bathroom) >_<
#156 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 05 March 2012 - 09:05 PM
All the best with the bathroom. But I am more interested in the roof repairs! It will be most interesting to see how you get the 'dishing' on the metal. As usual, my good wishes
Hugh
#157 minimuk
minimuk
  • 1,946 posts
Posted 05 March 2012 - 09:15 PM
Hugh
thanks for the bathroom support,..... the nearside corner was all dished by hand,hammer and dolly, I was able to do that as this was cut halfway between the top corner and the gutter. The offside corner cut out is higher, I plan to flatten the old piece, copy this on the donor panel and leave 13mm for the gutter lip and 13mm extra for the top. reason is to cut fins in the middle downwards to gutter and dish out the bit, when fitted and tacked on close the fins. That is the plan, but first clean out all the mess inside,.....
#158 minimuk
minimuk
  • 1,946 posts
Posted 16 March 2012 - 03:06 PM
good day today, some of you might have thought the repair on the offside will take another 2 month.......
went in the garage today at 9 am, pushed Muk out of the way, and made some space to play
offside gutter clearing/cleaning
soaking with zinc primer
cut out two repair pieces and trial fitted the first one
Attached File  front roof repairt trial fit first piece.jpg   51.18K   13 downloads
tacked on and seamed after
Attached File  front roof repairt tacking first piece.jpg   51.55K   13 downloads
left with small piece to be offered, tacked and seam welded
sanded the welds back, looking good
Attached File  front roof repair sanded welds back.jpg   49.05K   14 downloads
drenched the lot with zick primer
Attached File  front roof repairt zinc primer on sanded repair.jpg   45.14K   16 downloads
not bad, seam sealing tomorrow,.....
Edited by minimuk, 16 March 2012 - 03:06 PM.
#159 grahama
grahama
  • 2,442 posts
Posted 16 March 2012 - 04:36 PM
Nice repair as ever. What is the primer you have used, Zick, is that bit a typo lol ?? Is that the roof done, what's next??
Graham
#160 minimuk
minimuk
  • 1,946 posts
Posted 16 March 2012 - 04:43 PM
'Zick' is very special.....the plan of attack today was different then planned origionally, but that is part of fabricate as you go along. Next one is the rear panel and roof repair, lot of bracing to do first.
Edited by minimuk, 16 March 2012 - 04:48 PM.
#161 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Looking very Good.
Alex
#162 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 16 March 2012 - 10:04 PM
Fantastic contouring! Is the edge of your panels plug-welded to the gutter flange? These are super repairs.
Hugh
#163 minimuk
minimuk
  • 1,946 posts
Posted 16 March 2012 - 11:13 PM
Hugh
Hugh, the old cut out corner was welded that way,after clearing those(pain in the neck),I plugwelded the repair pieces to the gutter, as mentioned before will do seamsealing tmr and then the big one,..........the whole rear panel >_<
#164 frasermini
frasermini
  • 80 posts
  • Local Club: no
Posted 17 March 2012 - 07:33 PM
Been following this for a while, coming on nicely!!
#165 minimuk
minimuk
  • 1,946 posts
Posted 17 March 2012 - 10:55 PM
cheers fraser, this is a project which takes time and a lot of planning, so will be slow I am afraid.....
